Car is in the shop to have the trans leaks addressed.
The good news?  I was able to grab pix of the numbers on the trans as well as the pad at the oil filter. Everything lines up as expected.  The numbers on the trans look to be half-assed by whichever assembly line worker was tasked with stamping that day, but it’s confirmation nonetheless
The bad news?  The coil overs as installed by the previous owner’s mechanic had nearly rubbed through both rear brake lines.  So custom bent lines it is, not to mention the hose on the passenger line was almost completely blocked/collapsed. Better than losing rear brakes on a road trip, I guess.
Meant to say the hose that splits to both rear lines was toast.
Glad to hear you confirmed the numbers to the engine and transmission. You could get stock replacement lines or stainless lines and "tweak" them where needed. I got mine from inline tube.
Thats great news Glen!!!! Alittle work, but thank goodness you found them now with no problems. The matching engine and tranny numbers makes it a great day!!!!
:yay::yay::yay:
