jft69z Posted July 5, 2021 Posted July 5, 2021 Maybe Legendary. They wanted to sell me some when I had my interior done, but I just sprayed mine to freshen them up. They were crazy money if I recall, which is why I sprayed the originals. Quote
Dtret Posted July 5, 2021 Posted July 5, 2021 I did the same as Joe. Scuffed and sprayed with interior matching paint. Then I flipped them and put them on opposite panels so the wear pattern was hidden. Quote
jft69z Posted July 5, 2021 Posted July 5, 2021 12 minutes ago, Brew said: Tried Legendary. No luck😕 That's odd, they wanted something like $190 or more if memory serves correct. Enough that I looked mine over and said 'no way'. Like Dennis, I flipped them so the wear pattern was down. Did you call them, or just look online at their catalog? (I think my interior may still be the cover car for the M/C catalog) I'll try to dig thru the old invoices and see if there's a part number or reference when I get home later. Quote
Brew Posted July 5, 2021 Author Posted July 5, 2021 3 minutes ago, jft69z said: That's odd, they wanted something like $190 or more if memory serves correct. Enough that I looked mine over and said 'no way'. Like Dennis, I flipped them so the wear pattern was down. Did you call them, or just look online at their catalog? (I think my interior may still be the cover car for the M/C catalog) I'll try to dig thru the old invoices and see if there's a part number or reference when I get home later. I just looked online. They’re closed today Quote
jft69z Posted July 5, 2021 Posted July 5, 2021 They have them in their catalog. The numbers below are the color codes. https://www.legendaryautointeriors.com/wp-content/uploads/2018/10/2021-Monte-Carlo-Catalog-3.pdf 2 Quote
Brew Posted July 5, 2021 Author Posted July 5, 2021 3 minutes ago, jft69z said: They have them in their catalog. The numbers below are the color codes. https://www.legendaryautointeriors.com/wp-content/uploads/2018/10/2021-Monte-Carlo-Catalog-3.pdf Thanks . I will call them ! Quote
Brew Posted July 5, 2021 Author Posted July 5, 2021 What would the thing the ESCUTCHEONS slide onto be called? Quote
jft69z Posted July 5, 2021 Posted July 5, 2021 Official name, don't know. Legendary just says to "re-use original trim end caps and mounting brackets". Quote
bob 71 Posted July 5, 2021 Posted July 5, 2021 joe thanks for the info i need to replace they r coming apart at the inside seam. have u ever been to olcott beach car show Quote
jft69z Posted July 5, 2021 Posted July 5, 2021 5 minutes ago, bob 71 said: joe thanks for the info i need to replace they r coming apart at the inside seam. have u ever been to olcott beach car show You're welcome Bob. Yeah, we go every year usually. There's 2 actually, the earlier one is the 'Pirate's Festival' or something like that, usually smaller than the main one. The big one gets in the vicinity of 1000 cars or so. Lot of stuff comes from Canada and Rochester NY for that show. Quote
Dtret Posted July 5, 2021 Posted July 5, 2021 Just now, jft69z said: You're welcome Bob. Yeah, we go every year usually. There's 2 actually, the earlier one is the 'Pirate's Festival' or something like that, usually smaller than the main one. That one gets in the vicinity of 1000 cars or so. Lot of stuff comes from Canada and Rochester NY for that show. And you say you’re not a car show guy. 🤔 Quote
jft69z Posted July 5, 2021 Posted July 5, 2021 1 minute ago, Dtret said: And you say you’re not a car show guy. 🤔 I take my daily driver up there, walk around for a couple of hours, then go home. Quote
Dtret Posted July 5, 2021 Posted July 5, 2021 1 minute ago, jft69z said: I take my daily driver up there, walk around for a couple of hours, then go home. I understand. I’m good for hour or two then I’m done Quote
jft69z Posted July 5, 2021 Posted July 5, 2021 5 minutes ago, Dtret said: I understand. I’m good for hour or two then I’m done No way I'm sitting there all day, land locked in and can't leave. Especially since they start real early, lining up 1000+ cars, etc. Nope, I go, enjoy everyone else's hard work and nice rides & go home. Quote
bob 71 Posted July 5, 2021 Posted July 5, 2021 well im a glutten for punishment booked a room for 2 days going to see what else to do. getaway weekend not far from niagra falls Quote
jft69z Posted July 5, 2021 Posted July 5, 2021 1 hour ago, bob 71 said: well im a glutten for punishment booked a room for 2 days going to see what else to do. getaway weekend not far from niagra falls I'll PM you my cell number. I'm about 100 feet from Niagara Falls city line. If you stay around an extra day or so, there's a good cruise night on Mondays at the old Wurlitzer factory in N. Tonawanda. Usually gets over 500 cars. Quote
MCfan Posted July 5, 2021 Posted July 5, 2021 7 hours ago, Brew said: What would the thing the ESCUTCHEONS slide onto be called? Brew, Not to be nit picky, but those end caps don't actually "slide" on to the mounting brackets. Instead, they are made to "snap" onto the mounting bracket once they are properly positioned. I don't have a photo of the back of an end cap, but the ones on my '70s had a small spring steel catch that clamped onto the outer edges and the inside end of the mounting bracket to keep them from sliding back off the end of the strap/bracket when in use. It sure looks like they should slide onto the side rails of those mounting brackets but they actually have to be positioned over the mounting bracket and snapped into place. I encountered one end cap that would slide a bit on the bracket and discovered that the end of the spring steel clamp and been broken off, likely by trying to slide it into position on the bracket. I found that it was easy to remove them by simply snapping them off the bracket with a flat blade screwdriver (as shown in the attached photo) so replacing them just reverses that process. Good luck. 2 Quote
7tonemonte Posted July 6, 2021 Posted July 6, 2021 I never put the straps back on my car when I redid the interior. Kinda like it that way Quote
