Catch, spring...I don’t know what it’s called officially.
I’m looking to break this down, clean it up, powder coat or paint & reuse it.
I don’t think the spring pushes the hood up far enough when latch is released. has anyone dealt with that issue? I know it has a straight slot adjustment & I’ll try that. Just looking for any do’s or don’ts folks might be aware of. Thanks
Did you adjust the hood hinge properly that should pop when you release the hood latch?  Mine does the same as I had my front end removed then put back together as I haven’t gotten to adjust the hood hinges yet.
The spring could be wore out also. The one on my chevelle the spring had broken at some point and was completely gone.
Seems to be a lot of threads sticking up the top. Maybe it just needs to be adjusted, listen jam nut and turn with a large screwdriver retirement jam nut while holding it. Here's the one off my spare hood and the one on my car. Mine probably needs to be adjusted too.
Hey, Brew,
I had the same issue on my '70 SS several years ago.  I knew better than to mess with the hood hinges (heard too many horror stories) so I went to my large assortment of spare coil springs and selected one that just fit over the bolt and was long enough and strong enough to become a "helper" spring.  Once I added it to the assembly, the hood popped up far enough that I could get my fingers under the lip to open it.  It's a simple mod and hardly noticeable once it is in place.
7 minutes ago, MCfan said:
Hey, Brew,
Great idea I love it, think that's what mine needs. Now to find a spring that works.
Took my spare one apart today and sandblasted it got it all primed and ready for paint, first coat done. I'll go tomorrow to try and find an extra spring to fit inside the other one. I'll let you know how I make out.
2 minutes ago, cny first gen 71 said:
I know no pictures didn't happen,  here you go
Isn’t that supposed to be dark grey phosphate. You put the picture out there. Lol. Sometimes that’s why I don’t post pics. I don’t want to do it again. Lol.
On 8/14/2021 at 4:03 PM, MCfan said:
Hey, Brew,
Dennis a million thank yous for that tip, mine works great now. I had the extra one I have apart already so I went to hardware store found the right spring and put it back together tonight adjusted it and it's never worked this well. That's why I love the place and everyone here. My hood barley opened when I pulled hood release and when closing it I had to pull the release out to get hood closed, now it pops up enough and I can just drop the hood to close it. It's like day and night.this is all it popped up before and then after. Took a little adjusting to get it perfect but it's great now.
You're welcome, Steve, good to hear it worked for you, also!
This is a great site for sharing fixes, tips and techniques.  I've picked up quite a few from others myself.
Great advise. Good ideas. I wish I would have found this place 6 years ago when I bought my money pit. 😎
Dennis, any idea what the dimensions are on that spring?? It would be nice to pickup a spring before the part rebuild.
Wouldn’t that be a Monte pit ?  Lol
Sorry, Paul, I don't know and I sold my SS a couple years ago so I can't check.  Maybe Steve (cny first gen 71) can answer your question as he just bought a spring from a hardware store that worked well for him.
Actually I can't answer that question I didn't measure it, if they get more in at the store I can get specs. The one I got was the only one they had, I  actually took it off display board.  I'll check back with them if they get more in stock the guy said he will order more.
That would be great, I could take it off now but I'm thinking this would be a good project when the white stuff flies. But then again I guess the car is off the road all winter so I would have plenty of time.
Don’t be bringing the “white stuff “ into the conversation yet. Way to early
I agree, but I am setting up some work for the Monte. I don't want to tear it apart while the weather is good
I fully understand. I’m making after fall plans for the car also. Summer is just going by to quick. I don’t want the cold 😂😂😂
I stopped back at the hardware store, here is the display board I got the spring from. As you can see I took it off display board. It is #54 they will be getting more in but anyone that sells this brand should have them. Hope this helps.
Let the search begin, thanks
