7.4L
    Seattle
    Don McClumpha
    Retired
718 profile views
  1. I had a chance to look over the car again today. The A/C compressor does actually engage when the engine is running and you turn on the A/C. It doesn't blow cold, but the entire system is intact. I noticed the radiator tank was stamped Harrison. The tag attached to the radiator and is stamped "BR." The alternator is stamped 1100843 61A. I'm actually amazed how well it runs and drives for an unrestored 47 year old car. I pulled the distributor cap and it had decades worth of corrosion on the contacts. The plugs and wires look ancient. I wonder how much better it would run if it had a fresh tune up.
  2. See linked pictures for additional details: https://imgur.com/a/nEVzR Single snorkel air cleaner has 454 sticker. Block is stamped "CE171187." Warranty replacement blocks are stamped CE. Turbo 400 Transmission tag is stamped "70-CR" and the sequential number to the car is stamped on the driver's side of the transmission case. Rear end is stamped "CRJ" it's a 12 bolt with 2.56 gears. It has rear sway bar with boxed lower control arms. 15" Rally wheels with new tires. There's an assembly on the bottom of the frame which attaches to the upper right rear control arm. Rear heavy duty frame braces that attach to the control arm mounting brackets. Air conditioning. There's a large tank on the left inner fender well under the hood. Power disc brakes and power steering. Fiber optic windshield washer bottle. Power windows, bucket seats, center console, tilt steering, 3 spoke steering wheel, tach with gauges, rear window defogger, AM/FM stereo 8 track with 2 rear speakers, rear view mirror light, visor mirror, courtesy lights, deluxe seat belts, tinted glass, and driver's remote mirror. Paint code 58 Autumn Gold, vinyl top code H gold, Trim code 769 strato bucket seats with vinyl saddle interior. Build code 10C is third week of October 1969. Built at BL Van Nuys assembly plant. The car was repainted years ago a slightly darker color than original. The gold vinyl top was replaced with a black one at the same time. Front bumper was likely replaced since it does not have bumper guards. Driver's fender has 1 landing not 3. Bumper filler panel has GM sticker on bottom. All other sheet metal appears to be original. No rust on the bottom side of the car. No evidence of any previous patch panels or rust repair. Trunk floor is very solid and doesn't have a single pin hole in it. Tiny spots of rust in both rear wheel lip openings just starting. One fender is rust free at the bottom. The other has a small spot of rust below the trim. Passenger SS454 emblem is on the car. Driver's side emblem still attached to trim and sitting inside the car. The Monte is very straight. Valve covers are chrome not painted. Holley carb not quadrajet. Motor starts right up and runs strong. No smoke or mechanical noises. Car pulls very hard and transmission shifts well. Approx 2k RPMs at 60 mph. Drives nice and straight without squeaks or rattles. Headlights, dash lights, turn signals, brake lights, courtesy lights, console light, trunk light, and rear defrost all work. One tail light out. Radio makes static noise. Tilt is very tight. Steering wheel is very nice. tach and all dash gauges work. Gauge faces very nice. Clock stopped working circa 1970. Heater works. Fan works on all speeds but high. Did not try A/C. Belt still on compressor. Carpets are decent for age. Both front seats have small tears starting. Console is cracked. Rear seat dirty, but in tact. Headliner surprisingly nice for 47 years old. All power window motors work. Exhaust has nice note. Windshield is cracked on passenger side. Car drives well for age. Odometer shows 80k. Last title transfer was in 1981. Same owner for 36 years. 8.5x11" paper sheet was attached to the top of the gas tank. Very dirty and decaying but cleaned up well enough with a tooth brush to read most of it. Paper reeks of gasoline. Numbers in upper right corner match VIN number on car. Engine box says "RN" transmission box says "CR" rear end box "RJ." Built in Van Nuys. Shows paint code 58, top color H, and trim 769 same as cowl tag. Originally delivered to Chuck Olson Chevrolet in Seattle which is still in business. Car is currently located about 50 miles from dealership. 40 entries spread over 5 columns. Some are very hard to read but appear to be the following: = AK1 DLX BLT&FT HN A01 ALL TNTD GLAS * A02 TNTD W/S = A31 POWER WINDOWS = A51 STRATO BK ST B37 FLOOR MATS * B80 ROOF DRIP MLD B93 DR EDGE GUARD * B96 R WHL OPG MLD CD2 W/S JAR MONIT = C08 VINYL TOP C50 RR WDO DEFOGG = C60 AIR CONDITION D33 REM CTRL MIRR D34 VISOR MIRROR = D55 CONSOLE GW4 256 RATIO AXL G67 AUTO LEVEL CONT * J50 POWER BRAKES * JL2 PWR DISC FR LS5 V8 454 = M40 3 SPD AUTO TR NK1 C??? steering wheel??? N33 TILT STRG WHL N40 PWR STRG P90 G70x15 T60 HD BATTERY UF1 MIRROR LAMP UM2 RDO AM-FM&TPE U14 IP GAUGES U25 LUGG COMPT LP U26 UNDERHOOD LP * U27 GLOVE COMP LP U28 ASH TRAY LAMP U29 IP LAMP * U35 ELECT CLOCK U76 W/S ANTENNA V31 FRT BUMP GRD ZJ7 SPL WHEEL EQUIP Z20 MONTE CARLO SS
