bustoff
bustoff last won the day on June 25 2015
bustoff had the most liked content!
1 Neutral
    ingleside il
    greg muscari
    retired
821 profile views
  1. bustoff
    speedo gear
    anybody know offhand the right speedo gear I need went from a 273 to 373 seems to be about 20mph fast th400 275/60/15 tires thanx
  2. bustoff
    stall speed
    I installed a 468 with a 3000 stall conv now my trans is shifting soft my question is does the 3000 stall converter change the way it shifts ? ( before I was running 402 with the same th400 (no stall) and getting very firm shifts ( rubber ) now soft shifts )
  3. I pulled the motor timing chain was VERY LOOSE 5 degrees on crank about 12 degrees on cam that explaines why the it was so eratic anyway that motor is under the work bench and the 468 gets put in next weekend cant wait will post pics soon thanks for the help
  4. going to drop the fuel tank and see what it looks like in there, everything is set where it should be and car is not performing if that don't help motor comes out next weekend
  5. thanks I did most of that on both carbs jets squirters cam timing base timing total timing changed distributer advance with a 373 gear this car wont even spin the tires the so called experts are saying too much manifold for smog motor with peanut ports car ran much better stock
  6. installed a quick fuel 680 vac sec carb today same stumble does anybody know if the rpm air gap manifold is too much for this engine? (402 headers streetfire ignition) its making me crazy cant figure it out. ANY IDEAS?
  7. today same stumble just wondering if this intake carb combo is too much for stock cam try something different tomorrow go to a 28 nozzle and cross my fingers
  8. there was 40 nozzle on the carb the demon instruction manual said it had a 31 W.T.F put on a 35 runs much better need to adjust trans 1st gear shifts too soon raining out will try to adjust module tomorrow will post updates
  9. new nozzles and jets on the way will keep posted
  10. fuel lines and filter are brand new anybody know off hand what size nozzles came stock on a #1903 street demon carb? I want to step it up a few sizes but don't want to buy all 10 sets hope it cures this issue
  11. 72 monte 402 headers air gap manifold 750 street demon carb hei ignition stumbles off idle tried everything any suggestions would help
  12. just wondering if a edelbrock performer rpm air gap #7561 will fit under the hood my 72 monte with a 402 thanks love this site
