imr
imr last won the day on January 29 2020
imr had the most liked content!
    Redland, Fl
    Antoine St Paul
    Tech/Mech
    1970 SS 454
2,114 profile views
imr's Achievements
Newbie
Newbie (1/14)
  • One Year In
90
  1. its beautiful. looks to be worth the money
  2. well did you make the deal. I just heard a friend of mine bougt an Indian from a friend. the following week he was going to pick it up. The seller wound up in the hospital and didnt make it. the son sold the bike to someone else. the son had found the title while his dad was in the hospital. Hope you have heard enough wait until later stories to convince you to make your deal.
  3. Bond James Bond. If you say 007 i think Sean Connery. No other person comes to mind. I enjoyed his work. RIP
  4. find someone or someplace that restores corvettes. the seem to do the most rivetting of ball joints. there is even a corvette websight that sells the toold and rivetts needed.
  5. I believe it goes under the upper control arm
  6. That is on my list of favorite cars. i have never owned a 4 door car or a 2 door pickup. never rode in the front seat of a station wagon
  7. imr
    wont crank
    do you have a points distributor.
  8. I dont think you posted a picture of my car.
  9. 70 Monte with original sticker
  10. imr
    Joyful66
    Nice ride enjoy it every minute you have. I am sure you would make your dad proud.
  11. I agree with Tom. The pump is the way to go. you can also go with a smaller booster if your not looking for that stock look. i dont think a 9/16 hose will add much difference.
  12. If you go on ebay you will find the housing or the pump. they also reproduce them. I believe if you buy from discout or autozone your going to get a square pump body
  13. Xylene will work, slow dry so you can work with it. Acetone or lacquer thinner will work, i have used it all to clean plastic and rubber, just dont soak it.
  14. I have 12.5 volt at the starter Bat and when i turn the key i get 12. at the solwnoid wire. i have a heat shield on order but i dont think that is the issue
  15. if i remove the Solenoid wire from the starter and measure volts to the wire from battery ground i loose less than .5volts but circuit stays over 12 volts.
