mcsteve
2 Neutral
    rochester,illinois
    stephen burke
    carpenter
    1970 350 - Auto
    1970 SS 454
  1. thanks for the response. my old drive gear ( in trans) had 18 teeth w 2.56 gears. my trans rebuilder said he gonna put in a 15 tooth n we'll figure the other out when car is done. Used tci formula n comes out to 37.75 teeth so maybe a37 or 38 will work. just needed the correct website n your explanation. Thanks again, Steve
  2. i'm changing from a 2.56 to 3.31 rearend gear ratio. 1970 mc ss 12 bolt. my t400 trans is being rebuilt n my trans builder is not sure what drive/driven gears to use for the speedometer in the trans - gonna use 26.5" tall rear tire (245 60 15). i looked online at charts but are confusing to use? any help would greatly appreciated! thanks, Steve
  3. Are the load leveling valves considered right or left handed. I see on the Dayton Air website they offer both - I have the original but not sure if it works or which side handed it is? Gathering parts n pieces to start restoring now that i have retired!
  4. pacecarjeff.com lists the clamp sizes - 2 different versions of kits or you can purchase sizes in pairs. if correct restoration he uses correct "wittek" clamps n can date code if you wish ( for an added fee) . He also has heater hose n by-pass hose clamps for a correct restoration. Price-wise he's a couple $ cheaper than Ground Up. Hope this helps. He also has correct hand-stamped radiator hoses, ribbed heater hoses n pvc hose w/ check valve. looks like I should work for him! Steve
  5. hi Dan, mcsteve here, looks like you bought the car in Chandlerville, Illinois that i posted on this site back in february. He had 2 - 1970 ss montes he bought near Alton, Illinois just to flip them. I bought the other car (red w/ black top n interior). Supposedly the rearend in my car was out of your car - 2.56 posi: my build sheet says my car was non-posi 2.56. The vin #s were only 170 cars apart built at Baltimore plant. I looked for the build sheet in usual places (front seat backs n both halves of rear seat but just used mirror under front buckets to look). Triple black car will be really cool - that car is very rebuildable. Good luck with it! Steve
