Ed Wieder
Contact Methods
  • Yahoo
    ejwieder@yahoo.com
    Bella Viata, AR 72715
    Old cars and ballroom dancing
    Edward John Wieder
    retired
1,053 profile views
  1. I purchase two sets of wheel dollies about $100 a set. They work okay when moving a light car. When used on my monte two people can barly move it. What did I do wrong? Please tell me what dollies work in moving our Montes. Thanks, ejw71, Ed
  2. What is the camshaft duration and lifts for a 1971 Monte 350 ci. engine? Thanks, Ed
  3. Thanks again to FG responders. Ed
  4. Thanks for the replies. Ed
  5. Are the front and rear vertical bumper guards the same? Meaning can the front and rear interchange? Tks, Ed
  6. I understand that there are two holes on the brake pedal shaft. The master cylinder rod will have a different mechanical advantage depending on which hole is used. The lower hole is for power brakes and the upper hole is for manual brakes. In using a master cylinder with a 1 inch bore the pedal will be softer than using a 1 1/8 inch bore. Is it posible to harden up the brake pedal by placing the master cylinder rod at a different locationon the shaft? Thanks, Ed
  7. Thanks Dennis. Such a complete answer is always appreciated. My Monte is black but your blue is beautiful. ejw71
  8. Firm I purchased a rear disc brake setup for my 71 Monte said a 1 1/8 inch master cylinder is needed. Inline company, ebay seller, told me this upon receiving the goods and after saying his listing included all needed to convert to rear disc brakes. What difference, if any, would there be using a 1 inch bore master cylinder with disc/disc versus 1 1/8? Thanks, ejw71
  9. Thanks for the replies. Ed
  10. Are they a 1 inch bore? Tks, Ed
