70SS396
  • Veteran
    US Army
    Baldwin,Maryland
    PAUL D VALLE
    Retired
    None
    still searching
  • 70SS396
7,786 profile views
70SS396's Achievements
Enthusiast
Enthusiast (6/14)
  • One Year In
  • Reacting Well
  • Dedicated
93
  1. The M20 wide ratio has a lower 1st gear than the M21 or M22 which are the same.
  2. It should be a yellow sticker and the carb number will be different than non California cars. e.g. 7040504 instead of 7040204
  3. Patience and perseverance:)
  4. There are several ground paths to the lamps on the dash cluster. The screws that attach the printed circuit are some of them. The cluster is grounded by a black grounding conductor that extends from the dash harness to the cluster can which must be a solid connection. Another ground issue is where 1 of the ground paths is damaged or broken at the lamp socket nearest the drivers side speaker. The mylar invariably gets bent down to clear the speaker bracket and speaker.. As suggested in a previous post , it's best to run a test jumper from the chassis or emg brake assembly to each screw that attaches the printed circuit ground to the metal cluster can.
  5. The black and red stripes should be adjustable to suit your preferred shift points.
  6. Hey Rob, I was responding to Jason who recommended an aftermarket company. I am primarily an original restoration guy and also respect owners who choose to modify their vehicles. Over the years I have identified the resources who can do restorations that are not my forte and am happy to share them with members who are interested in originality. I posted to you awhile ago the the name and phone number of a guy who specializes in classic radio refurbusing and speaker reconing for 1970's GM cars. Best, Paul Not the one who fell:)
  7. Hey Jason, Thanks for your input. To be clear all of my posts are related to original restorations. Crutchfield does a great job with aftermarket equipment but does not provide 10 ohm speakers as required for original equipment radios.
  8. Oh, I didn't realize he was talking to me. Thanks
  9. The correct bracket and 10ohm speakers are available. As per my previous post ,I have the correct part numbers and contact info if interested. The speakers are original and have been reconed.
  10. Thanks for your concern Rob but I didn't fall. Hope I don't anytime soon. Best, Paul valle/ 70SS396
  11. The drivers side speaker bracket and speaker are unique. It is designed to clear the dash cluster. Aftermarket speakers may be the correct size but the mounting points are different. If you try to make modifications you risk damaging the printed circuit on the back of the guage cluster. All Montes with stereo or AC have the correct bracket and speaker. Cars with am radios without AC have a single speaker in the center of the dash. The best solution for the drivers side is to use the correct bracket and have the speaker reconed. If anyone is interested I can provide the associated part numbers. Hope this helps with your speaker project.
  12. The metal housing that the guages are in. There are several hex screws that make the ground connection to the printed circuit for the dash lights. The housing (can) must be grounded for the dash lights to work.
  13. You can do a test by removing the dash pad or access the cluster can from below. Connect a jumper to the emergency brake assembly on one end and touch the can on the other end. Of course turn the lights swith on .
  14. Hi Rob, Joe Vigil in Monrovia, California restores Delco radio's and recones the 10W speakers. He also sells original speakers, brackets and accessories. His number is 626 264 7233. I gave used his services are they are excellent. Good luck, Paul
  15. There are several ground connections for the dash lights. Stangeba has excellent pictures below. Note the back of the cluster can on the lower right showing the black ground wire. The other end not seen connects to the chassis . There are also several hex head screws that ground the printed circuit to the can. If the black lead is disconnected or broken your dash lights won't work properly. A good test is to take a jumper wire from a solid connection on the dash framework or emergency brake assembly to the metal cluster can .
