Court1984
1 Neutral
  • Veteran
    US Navy
    Stewartstown, PA
    Courtland Green
    Stationary Engineer
    1972 350 Auto
  1. Front brakes: Rotors Pads Calipers Caliper hoses Inner bearings Outer bearings Inner seals Rear brakes: Shoes Hardware kit Wheel cylinders Drums Belts Front end alignment Exhaust leak: Replace exhaust donuts Rear suspension: Replace rear lower trailing arms Total: $3000.00 Deposit: $1500.00 I asked for: Motor mounts Trans leak differential leak Exhaust manifold connection to exhaust Clank noise when you pull off Harmonic balance check Belts What do you guys think of recommendations and price?
  2. New springs and shocks on rear end can’t get one bolt out on top of shock any suggestions?
  3. 255 in the front 275 in the rear, it’s not even 3/4” maybe 6mm.
  4. Thank you all! Rear springs sounds very doable thank you @cbolt!
  5. My wife brought me a 72 MC for my 40th birthday!! So far I’ve noticed the rear tires rub the wheel well (275’s) but love the look, it’s also been slightly lowered. So suspension, carburetor, and electrical work is what I can see so far. I’m in Pa., near Harford County MD. I’m skeptical about taking it to any shop I’d rather do it myself but I’m a novice. Any recommendations or suggestions would be greatly appreciated. https://share.icloud.com/photos/07d6asQ26pb3jCiNptvl4-LNw
