FRANKIE T.
About FRANKIE T.
  • Birthday 02/04/1943
    QUEENS N.Y.
    OLDIES
    RETIRED
  • MONTENUT71
  1. Took her out on toys for tot's run and of course it rained but thats what towels are for. [/img]
  2. Found the problem with not starting. Had new starter and solenoid went bad " INTERNAL SOLENOID". Switched the solenoid from old starter & she started right up
  3. After Super Storm Sandy hit she got water up to the rugs.Took the rugs and insulation out and washed her undercarraige.Changed battery,cables and starter.Wont start unless i give her a good boost.Changed the horn relay and cleaned connections to no avail. Will have to wait for warm weather to trace the problem down. Garage too small to work in Took her on the road this week and everything else semms ok.
  4. After Super Storm Sandy she got water up to rugs so they came out along with the insulation.Changed starter and wires.She wont start unless i give her a good boost. New battery did'nt help nor did a new horn relay. Will have to trace everything down as soon as warm weather comes. Garage too small to work in.
  5. Probably will buy back. Dont want to give it up.
  6. Spoke to ins. co. and they totalled the Monte do to SANDY damage.Will make decision of bying it back Monday.
  7. I installed an electric fan from a Buick grand sport in my 350 monte with a/c. Have not had any overheating problems.
  8. Read up on everything you try to do yourself and you can do it.
  9. Do all you can yourself. Save's a ton of bucks. New project 1970 Lincoln Mark III Started Yea i know its a Ford.
  10. Went shopping for GARAGE DOOR. Garage should be up in 2-3 weeks Sketch of what it should look like. I have very limited space.
  11. Nice. I am truly impressed by your work. Get er done.
  12. any ideas???
  13. I have 235/60-16 tires on 16 x 8 rims in the rear with 4-3/4 back space and no clearance problems.
  14. Cleaning up posi rear to put in to Monte. Richmond 342 gears. 10 bolt.
