rpmracer70
About rpmracer70
  • Birthday 07/24/1967
    Indiana
  1. ok i will look into that and thanks alot for your help
  2. tires are 255/60-15
  3. i have a turbo 350 trans , i just changed the rearend i went from a 273 to a 410 and my speedo reads 70 when i'm going around 40 , i was wondering how to make it right is there a gear that i can change or do i go to a trans shop ? thanks
  4. hey guys i just picked up a 3000 stall from a friend i;ll try it out thanks all for your help
  5. i have a 350 about 400 hp with a 350 turbo trans and a 2400 stahl conv, when i put it in drive it pulls right away with no slip , the motor has a med size cam so i need it to slip at idle what conv should i use , thanks Robert
  6. Thanks for the info
  7. I have a 70 monte 350 about 400hp and 350 turbo trans with a shift kit and a 1800-2400 stahl conv but when i put it drive it pulls away with no slip is my conf junk ?
  8. ok i'll check that out thanks for your help
  9. rpmracer70
    info help
    i have a 70 monte 350 i just put headers on , i need to know what to do to hook up the power steering pump is there and aftermarket bracket or do i have to fab one thanks for your help
  10. I have the chance to buy 2 muncie 4 speed trans with extra parts, they have been sitting under a work bench for years but all the parts are there to make 2 good trans . and i'm not sure what they are worth if anyone knows could you please let me know thanks
