Wraith
    Arizona
    Joe Green
    Occupied
903 profile views
  1. Monte Start Problems Need some advice …. My Monte on occasion does not start. No real pattern other than it happens out of no where. It has happened from a cold start and it’s happened when warm after stopping to get gas. Does not happen often. When this happens all dash lights come on. No sound or indication of car trying to turn over and start when trying to start it. Buddy tapped on the starter and afterwards she started and ran fine. It recently happened two days in a row. I got under the car and tapped on the starter and that did not work. Crazy but I decided to open and closed the drivers side door a few times. Did that and she started. Drove for about twenty-minutes shut the car off and when I started it up over an hour later it started right up. This is unpredictable when it happens. My starter is fairly new, my battery is good. Alternator is good. Suggestions?? 70’ Monte 350 automatic transmission. Thanks!
  2. Wraith
    Engine Swap
    Thanks. I sent him a message through FB. I agree with you 💯 percent. Good advice.
  3. Wraith
    Engine Swap
    Lol ... I noticed the labor costs are let’s say a significant part of the cost. Unfortunately I can’t do it myself due to a couple of physical limitations so I’m stuck with the shop doing it all. But I want to be involved in this all along the way. Gears, no posi as is. I’m open to asking and learning for sure. You and everyone I’ve heard from have been incredibly helpful. Anything you can think of that I should ask or include etc please let me know. Thanks I really appreciate the help.
  4. Wraith
    Engine Swap
    I really appreciate your input and questions. Here’s the scoop. It’s a new LS3 engine w/ 495 HP 6.2L 4 speed auto transmission. Adding a/c as well. The shop quote is steep. After adding in fuel lines, suspension, upgraded oil pan etc. w/ labor it’s headed north Of $40k The engine alone looks like it’s at about $17k (Not sure if the cost would be much different shopping around) The shop was referred to me and they only do work on old cars, repairs to complete resto. I know they’ll want a deposit and then $$ monthly after that. I wish I had another shop to compare but I can’t seem to find another reputable shop that I can trust that is in state. On top of that I’m not from AZ. only lived here two years. I do not want to race the car but I want at least 400 or so HP. Just driving and enjoying the car is all with access to more power and clean dependable start and drive ability. Looking forward to adding AC and will be a huge plus. I was surprised to see line items on the estimate for suspension changes?? Thoughts?? Thanks in advance! I relocated to AZ. Due to the age of the car and how it’s registered I’m able to bypass traditional emissions testing/requirements. Looking to upgrade fuel lines, high flow fuel pump etc. A shop prepared an estimate which I just received moments ago coming in at about $17+ for the engine itself less mounts, upgrade oil pan kit etc. I’m having the shop do it all for me. I’m not able to do it myself. Just want to make sure I’m getting a fair shake.
  5. Wraith
    Engine Swap
  6. Wraith
    Engine Swap
    I am interested in having a new engine installed LS3 4 speed automatic with ac. I have an estimate from a shop. I’m wondering where the best place would be to buy from and what cost range I should expect? Any advice is much appreciated.
