Chad Stubbs
About Chad Stubbs
  • Birthday 04/12/1984
    Norfolk, NE
    Truck Driver
  1. What kind of fiberglass hoods are you guys running and how do you like them. Next week im going to order one and just curious on which i should go with. Im going to run a bolt on cause it will be a street/show car.
  2. I was wondering why my monte has four body mounts in the front by the firewall but my parts car only has two in the front they are both 1970 monte carlos
  3. I got my dads 70 to 141 on the airport. that is with aftermarket suspension. You sure dont want to turn the wheel the least bit i can tell you that much. the car is stock otherwise
  4. what 5 speed should i consider
  5. i have a 70 monte it had a manual in it originaly on the floor the guy that had it before me changed it to an automatic but left the clutch pedal in it so i was thinking of swapping it to a stick again but what transmission would have been in it? and also it has a 454 in it now so would the manal trans still bolt up. the motor is beefed up. acording to the dyno sheet it has 487 horsepower 525 torque i did not build the motor though so i need a stick that can handle that kind of power let me know what you guys think thank you for any help
