Clever1
About Clever1
  • Birthday 03/31/1970
Contact Methods
  • AIM
    Clever1ICQ
  • Website URL
    www.hsvautomation.com
  • ICQ
    1337096
    Owens Cross Roads, AL
    Home Automation
    Rich Cole
    Senior Engineer IV
  • Brass Member
  1. Clever1
    Running hot
    I found this picture of a 4 row chevelle radiator and it doesn't look like mine...
  2. Clever1
    Running hot
    I sure that we will get a few more responses... If I need to take a better picture (closer) let me know... Just want to make sure it is the right radiator before I have it flushed and checked for blockage... If it is wrong then I will just get a new al one with e-fans... That should fix my cooling problems...
  3. Clever1
    Running hot
    The thermostat I pulled out was a 195 degree... Montemedic: That is what I was thinking when I pulled it out. I haven't worked on a car in year probably over 12 years ago was the last time I even touched a wrench...
  4. Clever1
    Running hot
    IS this the correct radiator for a 454?? it doesn't look like a 4 core to me...
  5. Clever1
    Running hot
    I seen some white smoke in the exhaust this weekend so I'm thinking that I have something not so good going on...
  6. Clever1
    Running hot
    I'll take some pics Bones... And I will get the radiator checked and flushed... I did see pieces of chevy orange paint in the radiator...
  7. Clever1
    Running hot
    Not sure on the guage stage I just got it so all it new... I did check the coolant level today it was a little low and there was nothing in the overflow container... I filled it up and started her up ran her with the cap off the radiator and seen the coolant rise and fall once the car was above ~190 so I would say the thermostat is working and so is the water pump along with the radiator not being clogged; however, it is burnin very very rich as the exhaust was burning my eyes just getting the car up to temp... Major carb issues... I think I need to fix that first and see how that effects the temp... Thoughts???
  8. Clever1
    Running hot
    I spoke to the second previous owner who had engine mods done and he said that he never had a problem with it running hot. That it has a new radiator and clutch fan and thermostat. Talked to the owner I bought it from and he also made engine mods see the attached rebuilt sheet. Are the walls to thin now?? Is that what is causing the heat issues?? Previous owner said he didn't drive it much after the rebuild to notice any cooling issues.
  9. Clever1
    Running hot
    Thankx... Yes, I just got it so I have to put some time into it... I will check all those things out...
  10. Clever1
    Running hot
    Ok just got a 70 SS 454... The 454 hasn't freshly rebuilt and has been modified to be a 466, how hot should this thing be running?? And I need some ideas to help cool this thing down... I am up in the 230 to 250...
  11. You might try installing a new simultaneous dual-band wireless router as the 5GHz network would provide better service as there is less interference in that frequency range...
  12. Clever1
    ports
    You might try clearing your browser history & cookies...
  13. Stroker, what encryption type are you using??
  14. Any update on these parts???
  15. Jim, It would be great to know if your manufacturer finds that someone does make them and they are willing to pass that information along.
