kc8oye
1 Neutral
About kc8oye
  • Birthday 01/01/1979
Contact Methods
  • AIM
    KC8OYE
  • Website URL
    www.cardomain.com/id/kc8oye
  • ICQ
    2375417
    Roman Forest, Tx
    cars, Ham radio
    Delivery Driver - 777 Hunan Cuisine.com
  • I'm so much cooler online...
  1. kc8oye
    network issues
    mine is bigger
  2. oh boy.. if this wasn't a family site....
  3. kc8oye
    network issues
    i know ian. I'm not sure what the internet speed was at my cousins.. besides the obvious "turtle" Mom has 6mbit cable which runs circles around DSL. I was only getting between 1 and 24mbit to my cousin's router that's why I mentioned the speeds here at mom's for comparison.. I changed nothing on my computer except the router I was connected to.
  4. kc8oye
    network issues
    running a little slower tonight.. only 216mbit/s! I'm not sure if it's the router, or maybe this interface being that it's intended for high speed operation, just doesn't like doing 802.11g, or what..but I set mom up with the same wireless adapter the other day and her computer loves it too. I'm not using the NetGear software tho.. her machine is Windows 7, that was 'fun' trying to get that interface to work with 7... got it in the end tho.. and I'm of course on XP Pro sp3. is it possible the encryption method would make a difference? IIRC, that 2wire only supported WEP. I'm using WPA with mom's router.
  5. why on EARTH would he want to do it the RIGHT way???
  6. There should be no reason to remove the valve body for the TV/ kickdown cable.
  7. kc8oye
    network issues
    it looks like it was her router the whole time. I'm connected to a Belkin router right now using 'n' at 135mb/s
  8. you could also fill the holes with epoxy, such as jb weld.. then drill a small pilot hole in the epoxy and then re install the screw.. just a thought
  9. MonteFox... drain all the transmission fluid, remove the pan, remove the cable. CLEAN REALLY REALLLLY well.. spray brake cleaner works well here. let it dry well. goop it up with RTV, install the cable. LET IT DRY!! 24 hours minimum.. then reinstall the pan, refill with fluid, leak fixed. I've dealt with difficult dipstick seals this way b4.
  10. i think i could come collect in person
  11. you said above you didn't think you would have enough cam... I'm just sayin you will :>
  12. I've had excellent luck with Belkin routers too.
  13. 3.55's with 28" tall tires you will have NO problems in the 1/4 mile scott. I run 3.55's with 26" slicks, and my cam is all done by 4500 rpm and I can't quite make it through the quarter before I run out of cam.
  14. yeah my cable company in michigan was like that. When I switched from their cable modem to my own I had to call them and give them the new mac address.. thankfully their system doesn't give a cr@p whats behind the modem. I used a combination 4 port 100mbit switch/router at first.. then changed it to a wireless router when I got my laptop I've had good luck with my Linksys stuff at home.. I'm using a NetGear wireless adapter here and it sucks.. but then agian, so do the 2wire routers that I'm trying to connect to
  15. 600 lb ft and 500hp should do a lot better then low 12's unless your gears are REALLLLLLLLY wrong.
