wandalee
    NE
  • Member
  1. When I dropped the steering wheel it pulled out from the back of the cluster...
  2. Have any of you guys replaced a shift indicator on a column shift? How hard is it.... I need to replace mine....Thanks.....Wanda lee
  3. wandalee
    dash
    Just installed a reproduction dash pad from opgi....What a joke...doesn't fit at all.... has anyone used the dash cap that fits over the old dash//// if so how does it fit.....also has anyone sprayed a vinyl dye on the dash cap..... my dash color is dark saddle, does anyone know where you can buy the dye that would match..... thanks
  4. Thanks for the pictures....That's the way mine look..... wanda lee
  5. The rubber on mine extends past the chrome strip on the quarter window... It's in the body shop now I don't know if they were installed right....Can you give me a picture where the front side window meet te quarter window...... thanks
  6. Could someone post a picture of what the belt molding look like once installed ..... thanks... wanda lee
  7. Do you have to trim the molding to fit around the rear quarter window...... thanks
  8. Thanks...
  9. what holds the sail panel to the roof other than the rear window molding and the side panel?????
  10. What kind of carpet did you use.... Was it cut to size .... thanks
  11. What color are the original trunk mats..The only color I see offered is grey from opg...Also did original trunks come with side and rear boards.... thanks.... wanda lee
  12. I've seen it discussed before about how thin the lower replacement molding is and how careful you need to be when installing so it does't bend... Is there any out there that's better than the other..... thanks ..... wanda lee
  13. So Sam did you decide on what company to buy your wide belt moldings from? I need to buy some and would also like to know where to buy them...... Thanks Wanda Lee
  14. wandalee
    horn
    I have power to the horn, the horn must be bad.... tested earlier and it worked... Does anyone have a horn that they would like to sell...... thanks..... wandalee
  15. wandalee
    horn
    Hot wired the horn to the battery, it works, its a mystery.....I will check the power out from the relay..... thanks
