Shawn63 Posted October 13, 2013 Posted October 13, 2013 Hey Guys Does anyone have a wiring diagram for the ignition ,starting circuits on a 1971? I am removing my MSD and could use some help. Thanks-Shawn Quote
Toppless72 Posted October 13, 2013 Posted October 13, 2013 I'm not too good at creating links but if it works, I believe this will help you. 1971_chevelle_wiring It takes a minute to load but its worth the wait. Quote
stangeba Posted October 13, 2013 Posted October 13, 2013 "I am removing my MSD" What are you replacing it with? If you go with a standard GM HEI you will need to run full 12 volts. If you go back to Points, you will need the resistor. Bruce Quote
Shawn63 Posted October 13, 2013 Author Posted October 13, 2013 Thanks Joe Awesome diagram The help on here is great. Shawn Quote
Shawn63 Posted October 13, 2013 Author Posted October 13, 2013 Hi Bruce When I got the car it had the original point system,and an MSD box. I have heard a loud buzz,humm noise when the car warmed up. We first thought it was the transmission,but it turns out to be the MSD box. I would like to disconnect it and let the original system work. I am thinking of a Pertronix or a HEI at some point when budget allows of course. Shawn Shawn Quote
bigtankjones Posted October 13, 2013 Posted October 13, 2013 I have heard bad thing about Pertronix. Never tried them before. I have just stuck with the good Ole HEI. Quote
Shawn63 Posted October 13, 2013 Author Posted October 13, 2013 Thanks Tony What is a good source for HEI? GM performance or ebay etc. Shawn Quote
stangeba Posted October 13, 2013 Posted October 13, 2013 My two cents on anything "REBUILT" is have your own rebuilt by a small local shop or get a used one from the "Pick A Part" AKA Junk Yard and clean it up. Many many rebuilt items are not done correctly. Bruce Quote
Shawn63 Posted October 14, 2013 Author Posted October 14, 2013 Hi Bruce I agree on that,I worked for Napa for 20 years and have seen many "rebuilt" products come back under warranty. Shawn Quote
Malyc Posted October 28, 2013 Posted October 28, 2013 Topless, you wouldn't happen to have one of those for a '72, would you? Quote
Toppless72 Posted October 28, 2013 Posted October 28, 2013 Yep. With warning lamps 1972_with_lamps With Gauges 1972_with_gauges Try these. By the way... My manual shows the Monte Carlo and Chevelle to be the same but if anyone knows of any differences I would like to hear about them. Quote
NewTimer Posted October 28, 2013 Posted October 28, 2013 I have had petronix for over 5 years, not a single problem. Quote
Toppless72 Posted November 4, 2013 Posted November 4, 2013 Thank you. Wiring and wiring issues are my favorite things to troubleshoot on these cars. Quote
