wandalee Posted October 24, 2013 Posted October 24, 2013 I've seen it discussed before about how thin the lower replacement molding is and how careful you need to be when installing so it does't bend... Is there any out there that's better than the other..... thanks ..... wanda lee Quote
Michael Boyte Posted October 24, 2013 Posted October 24, 2013 You can send your original trim to Pro One Polishing in Hobart In.(219)759-5501 They can restore it to original or better. As for trim you can't beat the original pieces. The quality is much much better. Aftermarket is so easy to spot on a car Quote
overdrive Posted October 25, 2013 Posted October 25, 2013 I haven't had any problems with the repro 10 piece lower trim set, as far as it being thin and easy to bend. It's the long rocker panel trim that is so easy to mess up, but if you use the Auveco nylon clips you'll get a nice installation, as long as you are real careful. Dan Quote
