Getting ready to put vinyl top back on. But whoever had it before evidently cut the studs off i ordered the screws and clips but I found by looking at the parts car that there are some clips with screws on them that go thru the body and have a nut on the other side. Do y'all know if other clips like those from a malabu would be the right size. I seen them on ebay and they look the same
LeeLee the only studs that I know that uses nuts are the corner moldings and those studs are made on to the moldings. As for clips with nuts there was none on my 70 just clips that took a screw. Good luck with getting the suds back in the right location.
You can put them on with rivets or do I did and machine some and weld from back side before putting the panel below rear window and 1/4 panel on.A lot of work but didn't have anything else to do at the time
