cny first gen 71 Posted November 21, 2013 Posted November 21, 2013 I have patriot alum. angle plug heads for my small block and the headers I have will not work with them. Jegs lists headers that will fit bow tie angle plug heads. Does anyone know if they will work on these heads? Thanks in advance. Steve Quote
Toppless72 Posted November 21, 2013 Posted November 21, 2013 Could you contact the maker of the heads and see if they know what headers would work? They should know. Quote
badddoin Posted November 21, 2013 Posted November 21, 2013 I have those heads on my small block, too. My cheapo Blackjack headers worked, after I persuaded them a little with a ball peen hammer. I don't know the part number; I bought `em over the counter at Advanced Auto Parts. Quote
cny first gen 71 Posted November 22, 2013 Author Posted November 22, 2013 I spoke to tech line and they really wernt much help. I'll keep checking around. Quote
Tom Carter Posted December 13, 2013 Posted December 13, 2013 Steve, Â Knowing the headers I had would not work with the different angled plugs I started going the Jegs book. There are a few different options for the Monte Carlo including Patriot headers. I was thinking of giving them a try. I figured Patriot head with Patriot headers...what could go wrong...haha. I will let you know how I made out. Â P.s. I got the block back from the machine shop the other day. Reassembly starts this weekend...whooohoo Quote
Mike 57 Posted December 13, 2013 Posted December 13, 2013 I don' think patriot headers and patriot heads are the same company, but good luck with it! Â I had a similar issue with my AFR big block heads had to get these sockets and trim some 90 degree boots Quote
Mike 57 Posted December 13, 2013 Posted December 13, 2013 Steve, they are spark plug sockets that turn over the end of the plug. If you notice they have a notch in them and can get in a really tight place. If you can start the plug you csn use these to tighten them with a 5/8 wrench. Quote
Gonzo Posted December 14, 2013 Posted December 14, 2013 Mike where did you get those sockets? I have two plugs that are tough to get at and I think those would do the trick. Quote
Mike 57 Posted December 14, 2013 Posted December 14, 2013 Here is a link, not cheap but it really helps. these are for 5/8 plugs. linky Quote
cny first gen 71 Posted December 14, 2013 Author Posted December 14, 2013 Thanks Mike I may have to get them too. Quote
Gonzo Posted December 15, 2013 Posted December 15, 2013 Thanks Mike. Worth the price if they make the job easier. Why do you get 2 in a set? Is it just that one is shorter than the other? None of the descriptions I read say why there is 2. Quote
D.E Posted December 15, 2013 Posted December 15, 2013 Looks like the header mfg would give a little more room at the plugs because they have a ton of room in these cars.The bend at the plugs need to be a little longer to get boot on and a socket.look easy on the bench but not in car with a/c and all the other junk Quote
D0ublezer0x Posted January 9, 2014 Posted January 9, 2014 Make sure you guys are running header plugs too. Little shorter and makes life a lot easier. Quote
montique Posted January 12, 2014 Posted January 12, 2014 Yes they fit. I have the patriot headers with brodix track 1s and they are 1 3/4 tubes. They are not full length though. Quote
cny first gen 71 Posted January 23, 2014 Author Posted January 23, 2014 The ones i'm looking at are full length hedders Quote
