  • Replies 113
  • Created
  • Last Reply
Top Posters In This Topic
Trying too but money getting tight is making progress come to a slow again. Dam house repairs, lol
  • 1 month later...
Little update, front suspension is together mostly. Only need to order the sway bar, links and front hubs. And yes I know I've got to clean the spindle and backing plate smile
Anyone know where to get hubs that are not crazy priced? Some of these aftermarket ones are crazy expensive!
Very nice Keith, are those lowering springs?
Mike
Mike
Yea their my original Hotchkis lower springs I had when I had my 454.
Would you guys trust this for a hub setup being aluminum? Makes me a little uneasy with the size of are cars.
http://www.opgi.com/monte-carlo/1970/brake-systems/disc-brakes/CH30250/
These are the Kore3 ones, much nicer but really expensive
http://www.kore3.com/proddetail.php?prod=10075
Is there any other alternatives?
Thinking for swapping out a f-body 2001 style camaro brake setup complete onto the monte. But needs hubs in front.
  • 3 weeks later...
Starting assembling my fuel tank assembly from Tanks.com
I had some issue's with the stock float that came in the kit. It didn't allow for full movement up and down so the gauge would have been off. So I used a float arm out of a spare pump assembly I had for my daily driver. Works good but still a tad short.
I still have to adjust it some and then trim the excess rod off.
Here's the walbro pump assembly too, not a bad setup either.
  • 2 months later...
New steering wheel. Little better then the old Grant wheel! Like the wood grain matches the dash (don't mind the mess lol)
Ordered four new wheels. Ended up going with Voxx Old school wheels. Got 4-17x8's with a 4.75 backspacing, hoping they fit good.
And I also got all the brakes ordered for the front and rear. Went with 2001 F-Body 12" rotors all the way around. Fronts are on almost and rears are on there way. I've got to paint some of the brakets and such but going to be nice!
Looking good Keith, I havent done anything on mine. I havent even gone down th garage to work on fenders since I quit smoking (the garage is the only room I smoked in my house so i'm kinda avoiding it but will get back to it soon) Hope you have a great holiday season.
