72-CLASSIC_RIDE Posted March 15, 2014 Posted March 15, 2014 Hey guys, I learned something this past year while attending the WM. It was pointed out to me that the Headlight Extensions on my 72 Monte were of a 1970 Monte. Not having all the history of the car, I can only assume at one time there was front end damage and this difference became part of the repair. In order to gain a better understanding, I believe the core support is different from a 1970 vs. a 71 / 72. Is this the result of the difference from 71 / 72 headlight extensions (how they bolt up)? And would that difference also include the front fender mounting making the 70 fenders unique? I am considering replacing the headlight extensions for the correct year style and need to understand what that change would require (if any) in work/parts vs. just removing and replacing extensions. Appreciate any guidance you guys can offer. Doug
CKZ03 Posted March 15, 2014 Posted March 15, 2014 Makes me wonder if you also have 70 fenders. The bolt holes/pattern are different for 71/72 extensions. I think you would also have to cut recesses in the 70 extensions for the park/turn lights in the grille of the 72? I'd like to see some pics of that set up
Sam (Bones) Posted March 15, 2014 Posted March 15, 2014 I don't believe that '70s have a different chrome bezel too, it's more rounded than that of a '71/2, and you wouldn't be able to use your '72 park/turn lights, and '70 headlights are mounted closer "in" towards center compare to a '71/2 so you would have to have a '70 core support too, if you look at your front 2 bolts at the core support, and the front most bolt is "stepped" up, and the second one is lower, then you have a '71/2 sore support/fenders take a close look at my '70s chrome bezels are compared to your picture above
Sam (Bones) Posted March 15, 2014 Posted March 15, 2014 could you post a picture of your car front straight in front and of where the fender bolts to the core support we could be of much more help to you, but by what I can see of your signature pictures, you have the correct ones
CKZ03 Posted March 15, 2014 Posted March 15, 2014 I didn't even consider that the 70 h/l's are inset towards grille more, good point Sam. That would make this set up even more difficult to pull off, probably impossible with the width of the 72 grille
Sam (Bones) Posted March 15, 2014 Posted March 15, 2014 I looked threw your pictures on Photobucket, you have a '71/2 core support, whoever told you that must have been smokin some funny stuff if you look where the fender bolts to the core support you can clearly see the "step"
72-CLASSIC_RIDE Posted March 15, 2014 Author Posted March 15, 2014 Okay, good info for me. Good point on the headlight bezels and recognizing the core support of a 71/72 model! I will have to look at the bezels to determine year(s). I will see if I can find and post pic's to better describe the differences (1970 & 71/72)of the headlight extensions that were pointed out to me. Your observations have been and are instrumental in directing me to a knowledgeable conclusion on this issue. It has been bothering me since the difference was pointed out to me and was unsure what I would have to do to correct it. I'll get some decent pictures of my Extension/Bezels and post them. Thanks guys, Much appreciated...... Doug
Sam (Bones) Posted March 15, 2014 Posted March 15, 2014 you can not! have '70 extension on there because of the headlight location, worse case is some '71s customized to accommodate your turn/park lamps
72-CLASSIC_RIDE Posted March 15, 2014 Author Posted March 15, 2014 Okay, here's a pic showing front end and based on the info you guys provided can now see what you are saying. Whew! That's a relief. I was concerned if I had to make changes, just how deep would I have had to go and also, now less concerned there had been some type of front end damage. Also I noticed just visually looking at the inside edges of the extensions shows a difference in configuration as the 70's run parallel with the grill edges all the way up while to 71/72 extend further into grill at bottom top. As always, appreciate your responses and All have a GREAT day..... Doug
LostnFound Posted March 16, 2014 Posted March 16, 2014 Me too....I see nothing 70 about that front end.
CKZ03 Posted March 16, 2014 Posted March 16, 2014 Looks like 72 stuff to me too. That guy got you freakin out over nothing, bad info from him.
stangeba Posted March 16, 2014 Posted March 16, 2014 I once met a guy who didn't know he had a 70 ft clip on his 71. It's been over 40 years, people can change (mess up) allot of stuff on a vehicle.
Sam (Bones) Posted March 16, 2014 Posted March 16, 2014 and like a guy I met at Dream Cruise one year that said he had SS tail lights!
Canuck Posted March 16, 2014 Posted March 16, 2014 Who told you that your car had 1970 extensions? Those are all 72 parts you have on yours. I examined them closely while changing your water pump gaskets.
72-CLASSIC_RIDE Posted March 16, 2014 Author Posted March 16, 2014 Cant recall who pointed it out but clearly was mis-informed. I sum it up to a lack of knowledge on both our parts as I knew there were differences between those years but could not visually point out what the differences were. Geez Aaron! You coulda saved me all this heartache by sharing your knowledge with me back on that fateful day! Whats important is I have now been schooled on those differences and no replacement needed. Thanks all for sharing the wealth of your knowledge. Hope to become helpful myself in the future (after picking all your brains)! Doug
72-CLASSIC_RIDE Posted March 16, 2014 Author Posted March 16, 2014 I once met a guy who didn't know he had a 70 ft clip on his 71. It's been over 40 years, people can change (mess up) allot of stuff on a vehicle. True that! Learned just how much recently working on a 66 Elke! It just never seemed to end.......... Doug
Sam (Bones) Posted March 16, 2014 Posted March 16, 2014 now you know why this is the best club ever!!! Hmmm....now may I ask why I don't see the FGMCC MEMBER badge???
72-CLASSIC_RIDE Posted March 16, 2014 Author Posted March 16, 2014 Just got my 5 Year Badge Sam & will place it on my Grill before I kick off the fair weather driving. My side glass is generally down and I just don't like decals in front or rear window. But will proudly displayed on Grill this Summer! Doug
Sam (Bones) Posted March 16, 2014 Posted March 16, 2014 no...not that one the one under your profile here on the forum board, I know you are a member if you attended a meet, you have to be
72-CLASSIC_RIDE Posted March 16, 2014 Author Posted March 16, 2014 Okay Sam, guess your going to have to school me again. Now that I know which one you were referring to, how does that profile badge get displayed. Never noticed it before. Doug
Rob Peters Posted March 16, 2014 Posted March 16, 2014 According to the member renewal list, you are paid through 6/12/2015 Rob
Sam (Bones) Posted March 16, 2014 Posted March 16, 2014 you'll have to ask Scott, Aaron, Ian, or Andreas
Rob Peters Posted March 16, 2014 Posted March 16, 2014 I fixed it, I pinned your badge so you are good to go. Rob
72-CLASSIC_RIDE Posted March 17, 2014 Author Posted March 17, 2014 Thanks Rob. Wasn't aware or noticed it existed. Doug
