farmall Posted April 28, 2014 Posted April 28, 2014 I think I need to have my real main seal replaced. Does anyone have any idea how many hours a mechanic is going to hit me to change this? It has the 400 auto transmission. Quote
Mike 57 Posted April 28, 2014 Posted April 28, 2014 Shop around, it is a pain in the butt deal! Quote
Sam (Bones) Posted April 28, 2014 Posted April 28, 2014 it ain't going to be cheap here's an idea what's involved... disconnect battery ground cable remove starter, torque converter dust shield drain oil and remove filter remove engine mount bolts lift engine remove oil pan, oil pump, rear main cap now I personally like to loosen all main caps to get the crank to drop a smudge, makes it much easier the remove the old seal and install the new one clean the block and oil pan for new gasket re-torque the main caps and install the oil pump, oil pan and new gasket, lower engine, install mount bolts, trans dust cover, and starter new oil filter and fill the oil, connect battery cable I'll bet a minimum of 6 hours labor Quote
Ian Posted April 28, 2014 Posted April 28, 2014 I have done a small block in my sons truck in a afternoon. It is not that hard life you take your time. Use the felpro one piece pan gasket. Quote
farmall Posted April 28, 2014 Author Posted April 28, 2014 Sam, I was always under the impression that you could access everything by pulling the transmission. Is the way you described more efficient in your opinion? Quote
Mike 57 Posted April 28, 2014 Posted April 28, 2014 If the engine has a one piece rear main seal it is possible to replace the seal by removing the trans in some cases. Your 402 has a two piece seal in the rear main bearing cap. Quote
farmall Posted April 29, 2014 Author Posted April 29, 2014 I understand mike. A friend of mine does mechanic work. He said he would take care of it for me. Quote
jvssmail Posted April 29, 2014 Posted April 29, 2014 10 hours of labor to replace a 10$ part. its all labor. im doing a front seal on a tranny of a ford freestar right now and its a 16 hour job. part cost 22$ Quote
Mo's70MCs Posted April 30, 2014 Posted April 30, 2014 I have always had good luck with a "Sneaky Pete" Sneaky Pete It saves so much labor time. Quote
