Well picked up whats supposed to be an A body rear seat but the pattern doesn't match a Monte or Chevelle. IMG_0184_zps88bfc59f.jpgIMG_0185_zps32f316c0.jpg When measuring the rear seat in my 70 it checks out to 52" from side to side where this seat checks out to be 51" side to side.
Rob, that's a 70 Monte Carlo Rear Seat, atleast the pattern is anyway, identical to my 70.
I know my 70 looked exactly like that when I got it only in awesome green. grin
Mike
Spent a little time yesterday after getting back from dinner pulling the covers off the seat for a better look at the springs location. a> No changes need to be done to the seat bottom got it to lock in place. If you zoom in on the back of the seat you can see the tub is hitting three of the metal braces while the rest of the seat back needs to go back. So the game plan is to bend the two outer braces up to the springs the brace on the drivers side will be cut at the bottom and push over to the inside of the tub and move the mounting points to inside of the tubs as well.
got the seat springs painted this afternoon and even found the bottom arm rest to the rear. Still have the panel to put in that closes off the trunk to the rear seat, ran the rear speaker wire up to the deck the other week and got it running with the power window harness for the quarter windows.10513351_853169661384675_772179103272507
  • 3 weeks later...
Been cleaning up the core support for the 72 to see what will need to be done found some rust holes 004_zpsa1006c8c.jpg This section needs to be replace on both sides 003_zps6d3ccb32.jpg and then this area will need to be patched 002_zps5c9eb8d1.jpg thinking maybe a 71-72 Chevelle core support will work Fenders back on due to the weather change up here 008_zpse8153398.jpg  Nice alum elec door handles look good 009_zpsaf66354a.jpg
  • 4 months later...
Finally seeing good weather and am able to get the car back out of the garage to get work done on it plus clean up the garage. 11070740_935131403188500_799750881387896 still looking for some exhaust tips that will set the rear end of the car off and draw your eyes from the width of the tires.
Have a little more work to do with the front end going over the hood to fix some issue it has. 10409480_935131433188497_407562671688588
  • 7 months later...
Its been a while since I updated this post. So we forgo the 73 454 car motor on having it redone due to our work schedule and all the machine shops being close when we get home. Ended up pickup a 427 Tall deck motor which has 30k miles on it when pulled from a roofing companies tanker truck. Got the motor broke down to a complete long block - tins and the degrease the block which cleaned up well. Spent this afternoon and evening mocking up parts that were already on had for the 454 plus some new parts for the tall deck 10994178_1050507928317513_57889339762171 Thinking of throwing the EFI on the motor still have a extra Holley 750 on stand by plus the little Holley 600 that came with the motor.
More work done radio in the dash, dash back in. Headers are on and the exhaust hooked up. Need some chrome pipping to go around the radio opening. 12112404_1057448770956762_2024553641913011220480_1057448814290091_8617765139396412063878_1057448787623427_48171933544049
  • 4 months later...
Been almost two years since this project got started and its been a fun project to build, already looking for the finishing line or even a sale price. Yesterday the Hotchiks lowering springs and QA-1 shocks got dropped out in flavor of the Viking coil overs with 450LBS springs which is set at the lowest setting for the springs. Went ahead and bolt the hood back in first time since the 427 tall deck motor has been in the car and found out that the dual snorkel air clearer won't fit. If that is a sign on how the cowl induction air clearer is going to sit the snorkel on it might have to be reworked. 12795524_1126156304086008_41390348540018 Even thought its a work in progress it still looks mean just like that.
Lookin good Rob..keep at'er....I'm back in school now..so I'll follow your lead
  • 3 months later...
Shot a little color on the side of the car and broke it up with stock top trim. 13417402_1193153960719575_16550933332419  a black primer might make the colors darker but not sure if a darker color is what it needs.
What an awesome project! Lots of blood, sweat and tears going into it for sure. Looking great!
David
Don't know about the blood but it has been alot of sweat in this project. I'll be glad just to have it done getting tired of pushing it in and out of the garage. Here lately its been adding bondo sand off bondo, lets try those two colors and get a color plan picked out. This is what we came up with 13393936_1193682364000068_50494757417805 Dark toreador red as the main body color and then the center of the cowl induction hood and roof black cherry pearl. The center of the hood looks like it will tie into the roof fine with the top trim and the body line on the hood.
Lay some final color on the tail light extension today and must say the color turned out great for just throwing two items together. 13557797_1203625133005791_53497603894921 In the sun you can see all the metal flake and a hint of copper in the dark red paint.
  • 1 month later...
The trunk is getting one step closer on getting done. Went with a stand off bowtie instead cutting out the bowtie. Thinking 1/4" foam on the panels and maybe 3/8" on the bowtie to stand out a little more. 13876362_1232184263483211_70234998841078
hey Rob...is that a ford colour?.Dark toreador red....ha ya i spelled it colour..lol
  • 8 months later...
  • 1 month later...
  • 2 months later...
