Does this statement hold true for a '70 Monte?
"A 2 series carrier is a car that came with 3.08s or lower from the factory (i.e. all of your 2.73 cars). A 3 series carrier is a car that came with 3.23s or higher."
My assumption is that I have the stock 12 bolt with 2.73 gears and at some point I may want to get lower gears, something shy of 3.73. I've seen references to 2 series and 3 series, but wasn't sure how or what determined the designation.
Hey Drew,
IIRC 2 series carriers are just that. 2.73 and I want to say the even had like a 2.56 gear or close to it. 3 series is 3.08 up to 3.73 but you can purchase a thick ring gear set in 4.11, 4.56, and I think 4.88 that will fit a 3 series.
David
David,
DOH! I should have been able to make that connection but I guess it went right by me.
Would I be able to put 3.XX gears in a 2 series carrier?
  • 8 months later...
Resurrecting my post...
Out side of 70-72 Monte's and Chevelle's (maybe?), what rear ends would fit under my '70 in order to run 3.XX gears? Any Chevy's from the 80's or 90's?
Thanks.
cuttlas grand prix, lemans, GTO, skylark 68-72, in 73 the axle housing changed some
you can run a 3.xx gear in any axle with the correct carrier
68 - 72. Does that include Chevelle's on that list?
Thanks Sam.
I believe the only 2 series 12 bolt carrier that could accept a 3 series gear was the 12 bolt TRUCK carrier.  If memory serves me correctly,  a truck 2 series 12 bolt carrier could accept up to a 3.07 gear.  3.08 is definitely a 3 series carrier item and is a passenger 12 bolt gear.  You could also use ring gear shims to use series 2 gears on series 3 carriers.  I don't personally like them but some people do.  - Dave
After some more research on my part, the Ford in my link above won't work regardless, as it is a 5x5 bolt pattern.
There may be other reasons, but I stopped once I found that.
I ran across a '71 Chevelle 10 bolt with .308 gears in it, non-posi ($250 - and local). This should be a 3 series carrier that I could run some lower gears in, correct? Most likely 3.30's would be my choice, strictly street.
I currently have a 12 bolt under my '70 with no reason to think I don't have the typical factory 2.73 gears but I have not verified yet.
Any reservations with a 10 bolt?
I would spend the money and build the 12 bolt with a posi, I would first verify what's in your 12 bolt "before" I did anything, can you get the axle code off the front side of the passengers side axle tube and look it up without taking the cover off
http://westerndiff.com/wordpress/
Try these guys, they helped me get a 3 series carrier for my 10 bolt, very friendly and good service.
I'm not sure if they have carriers for the 12, but I'd imagine they would. They ship too!
