jayzi Posted June 14, 2014 Posted June 14, 2014 Hey guys. I'm on my way to install an AM radio into my Monte but I'm struggling with all the cables hanging around. Maybe someone can help... So what we've got here are three wire harnesses. First one has three cables: Yellow, Light grey, Black Second one has seven cables: Light brown, Dark Brown, Purple, Blue, 3x Black-White I guess this is the harness for the radio and at least the Light Brown, the Purple and 2x Black-White Cables are for two speakers in the front. But how do I connect these to the radio (which has 2x GND, SPK, LMP, 12V pins)). How do I even connect at least two speakers to only one SPK pin? The radio is not the original one, it came from a 72 Camaro. Third harness has three cables on a connector: Light blue, Orange, Yellow So I'm most interested in getting the radio and speaker(s) connected but these two other harnesses should also have a deeper sense. Which could it be? Thanks in advance Joerg Quote
Toppless72 Posted June 15, 2014 Posted June 15, 2014 OK, The 3 wire Harness: Yellow = 12 volt switched power + Radio power Light gray = Dial illumination powered with dash lamp circuit Black = Radio Ground 7 Wire harness: Purple = Right front speaker positive Circuit 924 Tan (Light Brn.) = Left front speaker positive Circuit 923 Brown (Dk. Brn.) = Right rear speaker positive Circuit 978 Blue = Left rear speaker positive Circuit 922 3 Black w/ white tracer = Speaker ground - one to both rears together and one to each front speaker Circuit 977 If you are hooking up an AM only, radio using these wire harnesses use the yellow/gray/black for power, illumination, and ground. For speakers you will only be able to power one speaker. Pick where you want the sound to come from and use those wires to power it. AM radios only support one 8 ohm speaker. The third harness doesn't go to the radio. It is for the heater resistor located in the top of the underdash blower plenum. Quote
jayzi Posted June 19, 2014 Author Posted June 19, 2014 Hi Joe. That was a great help. I got the radio running and somehow it seems to receive stations. There seems to be something wrong with the frequence control dial so I guess I need to look deeper into it. Just one question regarding the heater resistor cable. Do you know exactly where it needs to be connected? Tried to find it but without success. Thanks again Joerg Quote
monte70car Posted June 19, 2014 Posted June 19, 2014 heater resistor cable if its an air car would don't need as its part of the under hood harness for the a/c. If its a non-air car it will pug to the top of the box on the inside under the dash. Quote
jayzi Posted June 19, 2014 Author Posted June 19, 2014 Oh great, it is an a/c car. However I'm planning to remove the a/c. So would I need to connect it then ("plug to the top of the box on the inside under the dash") or won't there be a way to connect it? Quote
monte70car Posted June 19, 2014 Posted June 19, 2014 you would have to change the box under the dash which has the heater core in it for that plug to work. Since you are taking the air box off the firewall wall you will still have the wiring and switch under the hood. Quote
jayzi Posted July 4, 2014 Author Posted July 4, 2014 Hey guys. I finally decided to install the old radio but connect a modern one to the old switch. The new radio will be installed into the glove box. I will also install new speakers and new speaker cables. What's the easiest method to replace the cables for the back speakers? I removed the back seats but it seems to be the cables are running one level below and I don't understand how I can get access. Thanks Joerg Quote
footballubet Posted July 4, 2014 Posted July 4, 2014 It may be easier to pull the threshold plate and tuck them under the carpet and fish them up through to the trunk. Quote
Toppless72 Posted July 4, 2014 Posted July 4, 2014 The on the four speaker systems, the harness was installed by Fisher Body, not the assembly plants, the rear speaker wires run from a plug just above the glove box. They drop down by the right kick panel then along the right side of the floor beside the seat. If you remove the carpet trim in the right door and lift up the carpet you should be able to see a depression in the floor that is covered with tape. The speaker wires is under that tape. If you look in the trunk you should see the wires coming up from behind the rear seat on the right side. Quote
jayzi Posted July 6, 2014 Author Posted July 6, 2014 Thanks guys. Tried today to locate the cable and found out that it is somehow located in the middle of the car under the insulating compound. Since I didn't wanted to do a frame off resto only for speakers I decided to tuck the new cable under the carpet on the right side (as it should have been usually from the factory?) and as suggested. It was easy. Thanks again and have a great weekend. Quote
stangeba Posted July 6, 2014 Posted July 6, 2014 Here is a pic I took showing my 71 stereo rear spk wires all 3 of them. 71 rear speaker wires Quote
