bigscaht Posted October 9, 2014 Posted October 9, 2014 hey guys..i have developed a rear main seal leak..dam and the car isnt even on the road yet. so is it possible to replace this without dropping the tranny or removing the motor from the car??? Quote
Mike 57 Posted October 9, 2014 Posted October 9, 2014 Yep it is possible, are you sure it is the main seal? Quote
Sam (Bones) Posted October 9, 2014 Posted October 9, 2014 I was going to say the same thing, the oil pan could be the issue Quote
Murphy Posted October 9, 2014 Posted October 9, 2014 I thought I had the same issue, rear main seal........turns out it was a combination of the oilpan gasket and the distributor gasket! Quote
Rock Posted October 9, 2014 Posted October 9, 2014 I thought mine was leaking too. Turned out to be a small chunk of cork from the old valve cover gasket wasn't completly removed causing oil to run down the rear of the motor......I was a happy camper when I found that problem. Quote
bigscaht Posted October 9, 2014 Author Posted October 9, 2014 well yesterday i went home and got under there and checked things out. turns out its not the rear main seal..thank god..its actuallu the tranny leaking from the speedo bullet thing. time to replace the o rings on that. seems easy enough to do but where can i get those o rings from????? Quote
waupachino Posted October 10, 2014 Posted October 10, 2014 Are you sure it's the o-ring leaking and not the gear seal itself inside the Bullet? Mine was leaking due to the gear seal, and I just replaced the whole Bullet from here. They also have just the o-ring. Page down about half way. http://www.transmissioncenter.net/speedometer_calibration_______va.htm Quote
bigscaht Posted October 11, 2014 Author Posted October 11, 2014 actually im not sure..wasnt aware ou could buy the whole bullet like that..that might just be the way to go...thanks for that link Quote
bigscaht Posted October 11, 2014 Author Posted October 11, 2014 man that site was cool..ordered the whole bullet only 9 bucks....cool beans Quote
waupachino Posted October 13, 2014 Posted October 13, 2014 Yes it is a cool site. Just a heads up, have an Oil pan ready when you pull the old Bullet out. I made the mistake of not thinking much Transmission fluid would come out and flooded the Garage floor. Oops. Quote
bigscaht Posted October 13, 2014 Author Posted October 13, 2014 yeah i watched a video on youtube about replacing that exact part and that happened to the guy in the video.......thanks for the heads up Quote
Brent C Posted October 15, 2015 Posted October 15, 2015 I am about to do the same to my Monte. It is a 1970 with a 350/350TH and a 2.73 open rear. I am running 235 60 R15 tires. I figure since I am changing the bullett out I should put a new speedometer gear in to correct the speedometer. I am having a problem finding the new color and number of teeth I need for the new gear. All of the websites ask for the old color/teeth info. Is there a way to determine what should be in there from the factory without removing the original? I am trying to get it completed all at the same time without making a mess of the garage floor. Any help is greatly appreciated. Brent Quote
Murphy Posted October 15, 2015 Posted October 15, 2015 Brent, the link here has great info for determining driven gears and color combinations.... http://chevelleengineer.home.comcast.net/~chevelleengineer/speedo.htm You really should pull your driven gear to verify the color so you know which gear you need to order. 1 Quote
Rob Peters Posted October 15, 2015 Posted October 15, 2015 Great information, thanks for sharing it. Rob Quote
Brent C Posted October 17, 2015 Posted October 17, 2015 Thank you for thet information. I will pull the gear to make sure I get the correct one. Brent Quote
