Malyc Posted January 7, 2015 Posted January 7, 2015 So, I was wondering if anyone out there either has a monte that they converted to manual steering, and what kind of boxes would fit these cars. Quote
Boots Posted January 8, 2015 Posted January 8, 2015 OMG I couldn't imagine trying to wrestle these boats into a corner with manual Quote
Malyc Posted January 8, 2015 Author Posted January 8, 2015 I'm doing it right now because one of the lines for the power steering blew... Plus I'd like to take a bit more drag off the engine. I'm young yet, plenty of energy Quote
Malyc Posted January 8, 2015 Author Posted January 8, 2015 What about a manual box from a Chevelle? Did those even come with manual steering? Quote
overdrive Posted January 8, 2015 Posted January 8, 2015 Yes, they did. That would be the way to go. PS with a blown hose would be harder to turn than without PS. Â Dan Quote
Malyc Posted January 8, 2015 Author Posted January 8, 2015 Alright, sounds like finding one used would be the way to go... What years would fit? Quote
Malyc Posted January 8, 2015 Author Posted January 8, 2015 Found a manual steering box from a '69 Chevelle for $20 off ebay... Will that fit? And if so, will I need any other parts or is it an easy take out bolt in job? Quote
Leghome Posted January 8, 2015 Posted January 8, 2015 I have never found a just one bolt out job on my 72 Quote
Malyc Posted January 8, 2015 Author Posted January 8, 2015 Well, that was more an "Am I going to need parts to make it happen, or just the box?" type question. Â Though the engine swap would have gone quite smoothly if my cherry picker had 6" more reach. >.> Quote
Sam (Bones) Posted January 9, 2015 Posted January 9, 2015 you won't be happy with this conversion, nor do I recommend it for a monte, I would change to a tighter power box Quote
Malyc Posted January 9, 2015 Author Posted January 9, 2015 As it sits now, I'm having to run the power steering with no pump because it and one of the lines gave up the ghost. I'll see what I can find for power boxes, I guess. Quote
Sam (Bones) Posted January 9, 2015 Posted January 9, 2015 replace the line!!!!!! Â sure cheaper than buying another box!!!!! Quote
Malyc Posted January 9, 2015 Author Posted January 9, 2015 That's a thing that's going to happen too, though even before the line went the steering felt... unresponsive, I guess. Was just thinking about running through the whole thing to stop something else from going out. Quote
bigtankjones Posted January 10, 2015 Posted January 10, 2015 Why. I also cant imagine Wrestling with that Monster. I don't have my powersteering pump hooked up yet in my '70. I keep forgetting about no power steering when I move it out of the garage every now and thing. It's a pain in the Butt trying maneuver around the driveway. Quote
footballubet Posted January 11, 2015 Posted January 11, 2015 I would go with the Jeep Grand Cherokee PS box. It has a quicker ratio and all the parts for the swap are readily available.  I couldn't imagine trying to park one of these cars without PS. Quote
Malyc Posted January 11, 2015 Author Posted January 11, 2015 It's not -that- difficult... as long as you keep the car moving, anyway. Quote
Vinniepooh Posted January 12, 2015 Posted January 12, 2015 Look at this for the specs. You can find it elsewhere cheaper. Â Â http://www.speedwaymotors.com/1965-1991-GM-525-Manual-Steering-Box-w-3-4-30-Input-Spline,6723.html Quote
Vinniepooh Posted January 12, 2015 Posted January 12, 2015 It is as direct a bolt in as you would find (I think).. 6 plus turns stop to stop is definately not a quick ratio, but you won't get Popeye arms from driving atound either ! Quote
Malyc Posted January 12, 2015 Author Posted January 12, 2015 Already have the popeye arms from work, lifting tires that weigh an average of 125 pounds for 10 hours a day will do that. Quote
N/A86 Posted September 23, 2015 Posted September 23, 2015 I'm looking into manual steering as well what did you end up doing? It's not hard to drive a manual box car and there is way more steering feedback, I prefer it, I dailyed a elcamino with manual box and a tiny aftermarket steering wheel. Plus it's got to be 40lbs off the front end Quote
cny first gen 71 Posted September 23, 2015 Posted September 23, 2015 I've got a manual box out of a 64 chevelle not sure how good it is. Quote
LS5 Posted September 23, 2015 Posted September 23, 2015 Our Monte Carlo's did come with Manual steering as well on certain models. I know a fella that has a 1971 Monte Carlo and is a 402 4spd car and it has Manual steering from the Factory and also has NO clutch fan just a straight blade with no moving clutch at all also from the factory that way.. Sam you know who I am talking about.. Â Dont forget when you change the box you WILL have to shorten the Intermediate shaft length as the Power Steering shaft is longer. The manual box has about a 6-7 reach on the shaft from the box to where the knuckle or rag joint does up... Â Darren. Quote
Sam (Bones) Posted September 23, 2015 Posted September 23, 2015 I do not know that car, but I have seen a 350 2bl with a borg-warner 4 speed and manual steering stock  my 4 speed also has a solid 4 blade fan Quote
MCfan Posted September 24, 2015 Posted September 24, 2015 OMG I couldn't imagine trying to wrestle these boats into a corner with manual  My 402/4 speed was built with manual steering.  It was fine if the car was moving down the road, but nearly impossible to parallel park or turn around.  I put factory power steering on it and never looked back - what a relief! Quote
