201fireman Posted March 21, 2015 Posted March 21, 2015 I am removing the A/C and cleaning up the wiring under the hood of my 72 small block. The part pictured is on the passenger's side firewall. Can anyone help me identify what this is for and if it can be removed? Thanks! Quote
Sam (Bones) Posted March 21, 2015 Posted March 21, 2015 that looks to be your hi speed blower relay, you will need that unless you are doing away with the blower motor Quote
201fireman Posted March 22, 2015 Author Posted March 22, 2015 Ok, thanks! Just trying to clean out what I don't need without A/C. Quote
footballubet Posted March 22, 2015 Posted March 22, 2015 You could always rewire it so you can move that to an area that it's not seen as easily. I moved my horn relay (along with a couple other things) to under the dash when I cleaned up my engine compartment. Quote
