lopez70 Posted April 3, 2015 Posted April 3, 2015 Need some help with vacuum lines from heater controller. I removed dash and all air ducts while restoring. The original heater controller still attached with vacuum lines. I found my original vacuum tank but not sure I connected correctly. I have two 1/4" lines from controller through firewall. I believe one goes to tank and not sure where the other goes. Does anyone have a diagram for these lines and what doors they open? I think everything used to work 15 years ago but I need to make sure it does now. Thanks. Quote
monte70car Posted April 3, 2015 Posted April 3, 2015 Leroy the other vacuum line goes to the heater valve on the inner fender if your Monte is a 70. The vacuum tank holds the vacuum then its supply to the 1/4" hose to the control panel. The heater valve is open when the control panel is place in heat mode. In the top of the cowl there is a fresh air door which is control when the control panel is placed in vent mode along with a door in the passenger kick panel that will open. Quote
rsorg Posted April 4, 2015 Posted April 4, 2015 Hi, so when the control is on vent the cowl door and the passenger kick panel are open , when the control is off the doors should be closed? thanks Quote
