Hi folks.....I had brand new full length headers for my 84ss monte but decided to go with shortys on it because I lowered it. So I took the full lengths and put them on my 70 (small block). The fit was just about perfect but the drivers side hangs lower than passenger side and bottoms out every once in a while. Is this common? Could it be just cause they were for a different car? Or are drivers side typically lower than the passenger side? I'd hate to buy other headers if it's not going to make a difference.
Thanks for the help!
Juan
I know that Hooker Comps will hang a little lower on the drivers side. Hedmans are not quite as bad. My Schoenfelds are even but you must weld come sort of collector flange, be it a ball connector or standard 3 bolt.
David
my cheap paitroit headers hang pretty even..it might be because they were for a different year Monte...
