The addition of the 1" spacer allows me to only need 20 lbs of air in the shocks to get the stance I was after.............
Hi John, these are Cooper Cobras 235/60gt , 15", planning on a wider tire in back shortly...........
Hi Murphy, I have one more question for you. Is the rear 1 in spacer mounted on the spring perch or is there an insulator between the spacer and spring perch?
John S
Yes, it fits over the spring perch, I painted them with POR15 (several coats) and didn't use any insulator. My thought was that several coats of POR15 would eliminate any squeeking.........so far so good.
