farmall Posted May 23, 2015 Posted May 23, 2015 Hey there 4 speed experts, My Muncie conversion is going very well. (Thanks to the fine folks on this forum). I am trying to connect the clutch pedal to the z bar with the upper clutch rod or some call it a clutch firewall rod, depending who sells it. I just cant figure out which end goes to z bar and which end goes to clutch pedal. I have tried both ways and not having any luck. I was trying to copy and paste the part from the Ground Up website but just cant figure out how to do that. Anyway, it is part number FW 68 on their website ss396.com. Many thanks. Quote
Sam (Bones) Posted May 23, 2015 Posted May 23, 2015 are you ready to practice your cuss words? from inside the car..... slide the boot on the rod, the boot goes threw the firewall, not towards the pedal the end at the pedal points towards the left, as the rod goes threw the firewall, it angles down, then straightens back out the end at the Z bar points towards the engine the end at the pedal must be attached first (this is where the fun starts) I had to push the pedal down to put the rod in the pedal, I ALSO! had to take the clip off the pin for the brakes, and slide the brake pin out some it is a PIA to get the rod in the pedal put the rod threw the firewall then into the pedal, then the clip, then put the brake pin back together then attach it to the Z bar, then you can finish pushing the boot threw the firewall and put the screws in it trust me...it isn't as easy as it reads Quote
John S Posted May 23, 2015 Posted May 23, 2015 My description is not the best but here it goes. The rod has an offset bend in it. The longer end from the bend goes to the pedal with the end pointing to the left side of car. On the z bar the end points toward the engine. John S Quote
farmall Posted May 23, 2015 Author Posted May 23, 2015 ok...so I was doing it right I guess! I think I have forgotten how to cuss but I have a feeling that if I mess with this much longer, I might remember! Quote
Murphy Posted May 23, 2015 Posted May 23, 2015 It's like muscle memory, all of a sudden I started remembering words I hadn't used in 30 yrs. The key is to string them out so they make sense.....????? Quote
LS5 Posted May 23, 2015 Posted May 23, 2015 are you ready to practice your cuss words? I second that..... when I was working on the 4spd it was like I had Turrets all of a sudden..... Yeah thats what it was..... so does that mean I am excused...?? Quote
Sam (Bones) Posted May 23, 2015 Posted May 23, 2015 don't hold in the cuss words!!!! use them fluently and loudly!!!! you feel much better Quote
farmall Posted June 13, 2015 Author Posted June 13, 2015 The description that you guys gave is hard to put into words. Trying to describe how to position a crooked stick is tough. I rigged up the rod without the boot first and swapped the ends until it seemed to stay closest to the middle of the hole. Then I put the boot on the rod and reinstalled. Quote
Murphy Posted June 14, 2015 Posted June 14, 2015 Trial & error is usually how we figure these things out..........Good job! Now how about some pics! Quote
