Ooltewahman Posted July 12, 2015 Posted July 12, 2015 I've got a stock 350. I've been told to get the 600 cfm and then been told to get the 500 cfm. I have a 500 cfm on a corvette with a 327 and it runs great. Which should I get for the Monte? Quote
Rock Posted July 12, 2015 Posted July 12, 2015 I am running the 600 with no problem. I was told the 500 also but thought it would not be sufficient. Quote
Sam (Bones) Posted July 12, 2015 Posted July 12, 2015 a 500 or 600 will work, I wouldn't go more than 600 Quote
Leghome Posted July 12, 2015 Posted July 12, 2015 On my 350 CI 290 horse crate motor I am using a Eldebrock 1406 Quote
7tonemonte Posted July 12, 2015 Posted July 12, 2015 I have the 600 on my stock 350, electric choke one. Think it's the 1406 Larry mentioned. Bolted it on and went, never adjusted it, and it's been great for me Quote
Ooltewahman Posted July 13, 2015 Author Posted July 13, 2015 Ok thanks everyone. I bought the 600 today. Will I need to buy the adaptor? Quote
Leghome Posted July 13, 2015 Posted July 13, 2015 I had to put a spacer under mine but cannot remember why so I need to talk to my son in=law and find out so's I know if he remembers. Quote
monte70car Posted July 13, 2015 Posted July 13, 2015 Larry you might have put a spacer due to the bore of the intake spread bore to square bore. Quote
Leghome Posted July 13, 2015 Posted July 13, 2015 I think it was due to linkage problem with the intake that is on it Quote
VETTEWITHLEGS Posted July 14, 2015 Posted July 14, 2015 Ceramic spacer to prevent gas boilout at Taco Bell drive thru? that's why I put one in. Idle 2 minutes, then WOT when leaving, I died without the spacer. Quote
Ooltewahman Posted July 15, 2015 Author Posted July 15, 2015 I got it all installed. Spacer and all. Runs great. Now gonna have to figure out how to get the breather on without it messing with the throttle. I'm not sure if I have enough clearance to raise the breather up with a spacer. It's always something lol Quote
