Guys and Gals i need some help,
I just bought a truck to haul the Monte with once she is finished, 1979 Chevy C-30 with 454 mated to a th400.
I figured you all could help answer a few questions.
1.) is whiteish smoke out of the tail pipes a sign of a lean condition ? i think the #1 is fouled
2.) what size carb do you guys recommend for a 454 ? the guy i bought it from put a eddy1406 on it. which is only 600cfm
and it seems to surge at low speed(around 20 mph).
white smoke is usually water or antifreeze
does it clear up when warmed up?
a 750 cfm is plenty for a stock/mild 454
No signs of it being a water issue. i changed the plugs cap and rotor a week ago and no smoke after that and yes if i drive for about 10 minutes or so there will be no more smoke out the pipes. i figured the timing was of and the small carb wasnt helping the situation either
ok well im going to get it tuned up by my engine guy this week hopefully. Do you think i should upgrade to a bigger carb before i get that done ? or will the 600 be good enough
needs bigger carb before tune up so he can tune the carb to the motor. the white smoke sounds like a head gasket is seeping at worm conditions. after it sets take out the plugs more than likely find a plug wet
Thanks for the help on this one guys, i actually got a bigger carb for it an eddy 750 cfm and it's running a lot better. looks like the motor was just starving with that 600
