Anyone know where I can buy the correct upper control arm shafts?
my car appears to have had the rubber replaced - but the drivers side has shaft with threaded ends - and big nuts that hold the washer on -  the passenger side has the 3/8x24 bolt that holds the washer in place...
would like to get a pair of correct shafts and simply do it correct.
thanks
Rock Auto has them.
ACDELCO 45J0016 {#88913889} Professional
Front Upper; Offset Shaft Kit; Provides Additional Positive Camber Adjustment
($ 40.79)
MOOG K5250 {#3849412, 396678} Problem Solver Problem Solver; Control Arm Shaft
Front Upper; Offset Shaft Kit; Provides Additional Positive(+) Camber Adjustment
($ 37.79)
Mike
those are the aftermarket with the bit screw on the end - i want the original  OE shaft with the bolt that goes into the shaft on the end
thanks
Unless you have to have NOS, I'll bet Leo (KLASSIK1) can fix you right up.
