monteman70 Posted December 27, 2015 Posted December 27, 2015 1st if I get 2" drop spindles do I need to run 2" drop springs as well or is the point of the spindles so that I can run factory springs. Sorry if that's a stupid question. 2nd what's the difference between lower control arms that say oval bushings and round. (Obviously other then the shape). Can I just look at my stock control arms and just be able to tell what I have. Thank you Quote
monte70car Posted December 27, 2015 Posted December 27, 2015 2" drop spindles will allow you to run stock springs. The drop is where the brake rotor shaft is at. The control arms oval vs round is how the arms are designed. The round was Chevy first design and oval is the second design. Some say that's how you can tell a big block car from a small block car. Quote
Rob Peters Posted December 27, 2015 Posted December 27, 2015 Yes, it is easy to look at the control arm bushings to tell if they are oval or round. rob Quote
bigscaht Posted December 30, 2015 Posted December 30, 2015 mine came with oval bushings and is a small block car Quote
