My 72 monte used to have power front drum brake (strange for a 72 by the way...).
After an accident that damaged right front section, i've decided to convert to disc brakes.
So i've brought a complete kit from MBM, no kind of problem to install it, but after multiple bleeding, i can't manage to get good brake pressure and good pedal always feel poor.
Except if pump it but the pressure seems to fade away easily.
-All brake lines are new
-Rear brakes have been rebuild (wheel cylinder replaced), and correctly set
-New master have been bench bleed, and tested with plugs (pedal get firm fast and the pressure can be maintained)
-No leaks in the system
-Combination valve have been replaced from the kit and seems to work well
I don't really see where is the problem....
The only thing that can be in cause for me is the master cylinder bore size 1" from the kit, insufficient volume displacement for the car brake system, and i need an d 1"1/8 one
thanks by advance for the advices and sorry for incorrect English meanings (i'm a french owner...)
yes i did it, the one inclued in the kit seems to not work well.
Could that valve be installed backwards? They may only go in one way but thought I would ask.
Was the car built in Europe?  When the Monte came out in 1970 disc brakes were standard equipment . This was before the Chevelle had them as standard . I think another A body needed a brake upgrade and your car got the parts swapped out before a trade in or sale.  Sorry this does not offer any help to your question.
Usual 1" bore is used with 4wheel disc set, have installed those on all my 4wheel disc cars with no issue. Now if your pedal fades after its been applied it would be air in the system still or a leak either at a line. Since you switch from drum front brakes to disc you should need a 1 1/8 bore master this is give you the needed pressure for the disc drum setup. Also the proportioning valve can be the wrong one as a 4wheel disc system works differently then a disc drum one. Just my thoughts
No my car was built in baltimore plant, was export in 2000's
The last p.valve i've bought is for disc/drum setup.
And that's after complete bleeding (no air bubbles in bleed tube), i've poor pedal, no great difference between before and after, i can't "feel" the brake pressure coming during the bleeding, usualy, when you do it, and works well, the pedal gets a lot firmer after the rear brake're bleed.
in this case not...
make sure the rear brakes are adjusted, loose rear brakes will cause a low pedal
the combination valve may need to be reset too
while bleeding the brakes the valve can get pushed to the front or rear, this makes bleeding difficult, the valve needs to be centered and re-bled
you mean the valve that activate the warning light ? it stays in center after the bleeding
