How does the fiber optic ashtray light come out of its hole at the ashtray? Does it just pull out? Thanks, Danny
I've had my tray hanging down for a while so i went to take a look and it looks like to me that there is a sleeve clamped over the cable so it can't push in or pull out. I knows this is not much help but I believe it is pretty much stationary unless you want to enlarge the hole to remove it. Thats my 2 cents on the subject. Hopefully someone can help you more.
Ron
It's a tight fit. Drop a little bit of WD 40 and it should come out.
