Anyone know or can look up what 2 wires at the firewall bulkhead connector feed the factory dash amp guage or were under the hood ie regulator etc what 2 wires send the signal to it. Many Thanks in advance for any & all help.Boba
Hey Bob, the Amp Gauge wires are the Solid Black and Black with white stripe wires. They should be located on the Forward harness and when looking at the Block under the hood behind the power brake booster it will be the top of the right side block. Both have fuseable links in them at the other end by the volt regulator and the battery area when those links go you end up with problems or poor contact due to corrosion.
Darren.
Awesome Many Thanks, The printed circuit failed just for the amp & I want to hard wire because it such a hassle to replace the printed circuit foil.Mant Thanks Bob
