Recently I was swapping out my alternator and noticed it has some wort of wiring conversion, or deletion.
What's happening here and why?
Thanks!
Your alternator has an internal regulator. I am guessing the regulator has been deleted or by passed.
Doesn't it look as though there was part of that taped up wiring (about 2 o'clock) that used to plug into where that black plastic filler plug is now (12 o'clock)?
Is that the difference between an internal and external regulator alternator?
If it has a single wire and a ground then the regulator on the core support should be by passed. The original connector was removed on mine. There's a video about the procedure on YouTube.
Thanks Rock!
