I have some vinyl top trim that I'm trying to restore it wont look stock but it will be painted like stock. Right now there is piece of tape on the area that should be painted. What is the best way to prep the trim?
I used triple 0 (ultra-fine)  scotch brite pad and cleaned with lacquer thinner,then let dry and shot some self echting primer on the painted part, then used low gloss black.
Here is what my 72 might look like who knows when lol 13417402_1193153960719575_16550933332419 The trim will be held on with 3m double side sticky tape.
Robert, are you adding a vinyl top? Is the brown paint on the sail panel just for a contrast comparison? I saw a 72 Chevelle at a show one time that had a painted top, different color than the body. From a distance it looked like a vinyl top but once I got closer I discovered it was painted, anyway, my point is, he didn't install the trim to separate the colors between the top & the body. He had painted pinstripes that looked like trim, it was actually very cool.........
Murphy I will be using the stock trim to separate the two colors. The 72 is an original non vinyl top car but I like to be different.
I like the option of the Two-Tone paint job using the vinyl top trim to separate the colors. Mine is a Factory Two-Tone optioned car and it helps eliminate the vinyl rust trap but still have the contrasting colors.
