Pale340 Posted September 23, 2016 Posted September 23, 2016 Does anyone know of any vendor that makes the plastic covers that go over the shoulder belt mount up on the roof above the door? Thanks Chuck Quote
MC-71 Posted September 23, 2016 Posted September 23, 2016 No it is not reproduce. Try a search on ebay Quote
stangeba Posted September 23, 2016 Posted September 23, 2016 Leo may have some. Have you considered a Morris 3 point shoulder belt system? https://www.morrisclassic.com/ Quote
monte70z20 Posted September 24, 2016 Posted September 24, 2016 If I understand your message correctly, these are reproduced, I just bought a set from National Parts Depot and they fit perfectly here is the info: https://www.npdlink.com/store/products/plug_shoulder_belt_hole_mounts_at-183305-8.html part number is C-14875-61A $10.95 each. Quote
Pale340 Posted September 26, 2016 Author Posted September 26, 2016 That is it exactly. Thanks. I assume most paint shops would sell the correct paint/dye needed to paint the plastic the correct color I need it to be? Quote
72-CLASSIC_RIDE Posted September 26, 2016 Posted September 26, 2016 I would try Eastwood Coatings as an example for paint. There are a few who make colors formulated for reconditioning Interiors and supposedly, color matched. Pretty sure you will receive others opinions as I can't bring to mind other manufacturers. Eastwood is just a starting point. Doug Quote
