V8Freak Posted January 18, 2017 Posted January 18, 2017 looking for passenger and drivers side window guides if anyone knows if and where I can get these
V8Freak Posted January 18, 2017 Author Posted January 18, 2017 or do I have to some how rebuild originals?
Leghome Posted January 18, 2017 Posted January 18, 2017 I used some heavy duty Velcro to rebuild mine. I got it at Menards and it was fir exterior use and gray in color. It has worked out very well. I used the fuzzy side and discarded the hook side.
MC-71 Posted January 19, 2017 Posted January 19, 2017 Those don't look right. Are you sure they came out of your Monte?
V8Freak Posted January 19, 2017 Author Posted January 19, 2017 Yes sir, bottom of the doors, looks like it's purpose is to keep Windows somewhat stable when they are all they way down and you close the door to prevent window from slamming around inside, both my 70 I'm redoing and my parts 70 Monte have them
overdrive Posted January 22, 2017 Posted January 22, 2017 My '70 has a stop that's different from those. I've never seen that type. Larry, is this the part you used the velcro on, or was it the upper guides? I thought it was the uppers. Dan
Leghome Posted January 22, 2017 Posted January 22, 2017 Your right Dan it was the uppers I misread the post but I think it would work on those also but not sure.
V8Freak Posted January 23, 2017 Author Posted January 23, 2017 I think it will, that's what I'm going to try
