1970mcss Posted May 24, 2017 Posted May 24, 2017 Does anyone know if anyone sells Dark Green interior paint. My trim code is 784 Dark Jade. Jegs has a rattle can that is posted as 69 dark green. I'm not sure if it is the same. I'm looking to paint the steering wheel hub. Any help would be great. Thanks Paul Quote
Leghome Posted May 24, 2017 Posted May 24, 2017 Paul you might check out somewhere they sell SEM products. They have a wide variety of colors on their interior paint. I have used their products on my daughters car a few years ago and the color matched the factory color really well. Quote
overdrive Posted May 24, 2017 Posted May 24, 2017 Is it a satin finish? I think you should try the code in the pic and have a little mixed to check it. These codes are the colors used on the vinyl top trim and on the cars I've checked, it also matches the interior metal trim. If it matches yours, you can have a paint supplier put it in a rattle can, or just shoot it from a paint gun. Dan Quote
1970mcss Posted May 25, 2017 Author Posted May 25, 2017 I will check out both with my local paint supplier. The column looks like it's a satin finish. Thanks Paul Quote
RealRed70 Posted May 25, 2017 Posted May 25, 2017 What year car are you working on? 1970 used a Dark Metallic Green/ Dark Green Poly, 1971 used Jade Green, 1972 used Dark Green. The 784 code would be for a 1970. A steering column should be a low gloss paint. Different greens were used in 1969. Meaning more than one green. Quote
1970mcss Posted May 25, 2017 Author Posted May 25, 2017 Thanks Dan, I'm heading for the paint store Quote
bigscaht Posted June 8, 2017 Posted June 8, 2017 sem makes the paint your looking for and NPD sells it Quote
domnic6 Posted June 15, 2017 Posted June 15, 2017 Another vote for SEM. They have good products for restoring the interior pieces. Quote
1970mcss Posted June 15, 2017 Author Posted June 15, 2017 sem makes the paint your looking for and NPD sells it Thanks for the NPD heads-up. I ordered from them and hope its a match Quote
1970mcss Posted June 19, 2017 Author Posted June 19, 2017 Do I need to prime the steering hub before I spray it with the SEM paint??? Quote
bigscaht Posted June 19, 2017 Posted June 19, 2017 yes you will need to clean prep and prime before painting for best results...but really..u probally could get away with a good cleaning and some adhesion promoter sprayed on first.... Quote
Leghome Posted June 19, 2017 Posted June 19, 2017 also it might not hurt to sand the surface lightly with some 600 or 800 grit sandpaper for better adhesion. Quote
lastss Posted June 25, 2017 Posted June 25, 2017 Funny I purposely didn't repaint my steering column because of all the 46 yrs of key scratches. It only original once. Lol Quote
