silver71mc Posted July 1, 2017 Posted July 1, 2017 Front passenger side parking and signal light brighter than driver side. Not the bulbs, switched and replaced them, no change. Thanks Quote
Rob Peters Posted July 1, 2017 Posted July 1, 2017 Could be either a bad ground or bad socket or any connections along the way. I would start with the ground. The turn signal assembly picks up it's ground from attaching to the bumper and from the bumper it transfers through the housing to the lamp socket base. rob Quote
silver71mc Posted July 2, 2017 Author Posted July 2, 2017 Thanks, Rob Both are secured tight to the bumper, checked both grounds to the radiator support, they are tight. Guess I'll order a or buy a socket from somewhere, and swap it out. Not sure witch is bad. Quote
