Riznitch Posted February 3, 2007 Posted February 3, 2007 well the monte finally left me stranded. at least i was at work. anyhow, car ran great all the way to work but, at the end of the day i hop in it and it wont come out of park. i pulled the floor console to see if the shifter was malfunctioning but it was releasing. i tried to rock it to see if it would pop out of park but no luck.its a 72 th350. tell me something that will be an easy fix. Quote
Guest Posted February 3, 2007 Posted February 3, 2007 I had the same problem with one a few years back. It was the shifter cable, it worked fine then just froze up. Unhook the cable from the trans linkage and see if you can shift the trans by hand, If you can it's most likely the cable. Also try to move shifter if cable is bad it will not move. Make sure you apply emergency brake or block tires so it don't roll over you. Good Luck with fix !!! Quote
Rob Peters Posted February 3, 2007 Posted February 3, 2007 I don't know much about the Console shifters but in the column shifters the shifter can not be moved out of the park position unless the key is out of the lock position. Since this was a safety feature I would have to assume that this would be true for the console shifter. I would assume there would be some type of cable or electric solenoid lock on the shifter but my bet would be with a cable type lock. Again, I don't know this for sure and I am just guessing but it seems logical. Rob Quote
Donny vestal Posted February 3, 2007 Posted February 3, 2007 you might have to pull the pan off. the catch inside the tranny might have went to far.mine done that same thing.. Quote
RichG Posted February 3, 2007 Posted February 3, 2007 Rob is pretty close, there is a "back drive rod" that hooks to the gear selector shaft on the transmission, goes to a swivel bracket on the frame just below the e-brake, then up to the steering column. If you watch the column (where a column mount shifter would be) as you shift, you should see it move. It is what makes the steering wheel/ shifter lock system work. Could have trouble there. When you turn the key to start position, is the steering wheel free to turn? Quote
Riznitch Posted February 4, 2007 Author Posted February 4, 2007 Thanks for the tips. I should have time to check it out tomorrow and see if any of your ideas lead anywhere.RichG, hey man im from west chester, PA. nice to see a local on the FGMCC.I'm military so, im hanging out in vegas right now. Quote
7tonemonte Posted February 4, 2007 Posted February 4, 2007 Hey Riz, West Chester huh? I work in Exton and live outside Coatesville. Maybe Chester County is getting more popular with the FGMC's And RichG... finally making progress on the car, Ill be in touch soon. Tony Quote
Riznitch Posted February 10, 2007 Author Posted February 10, 2007 well i disconnected the shifter cable and was able to put the car in gear by turning the steering column. even with the cable disconnected i still cant shift so, i'll try and see if the shift handle is malfunctioning or if the cable just froze up. cant see why it would just freeze up though. Quote
Guest Posted February 10, 2007 Posted February 10, 2007 That's what happened to mine even after I removed the cable I couldn't get it to move, If you can try to get a genuine GM cable the aftermarket one's don't adjust very good. I bought one for mine and I could not get the cable to adjust for low gear and had too much at the park side. Bought a genuine GM cable on E bay Fit perfect. Quote
Sam (Bones) Posted February 10, 2007 Posted February 10, 2007 if you do not have a good body to frame ground, the shifter cable will act like one, and weld itself together I've personally see this a few times Quote
Guest Posted February 10, 2007 Posted February 10, 2007 if you do not have a good body to frame ground, the shifter cable will act like one, and weld itself together I've personally see this a few times Now you got me thinking, My cable froze up when the front clip was off the car and still had the battery hooked up. So the ground wire was not hooked to passenger fender. All was good before then. Quote
7tonemonte Posted February 10, 2007 Posted February 10, 2007 if you do not have a good body to frame ground, the shifter cable will act like one, and weld itself together I've personally see this a few times Could this happen with the e-brake cable also? Mine is stuck hard. Tony Quote
Sam (Bones) Posted February 10, 2007 Posted February 10, 2007 I made a ground out of a battery cable, hooked from the engine block to the body to make sure there was an GOOD ground, since the battery ground is hooked to the engine, it only made sense Quote
Guest Posted February 10, 2007 Posted February 10, 2007 I made a ground out of a battery cable, hooked from the engine block to the body to make sure there was an GOOD ground, since the battery ground is hooked to the engine, it only made sense Now I have a reason to go to the parts store and hang out in the garage all night Quote
Sam (Bones) Posted February 10, 2007 Posted February 10, 2007 you must be married don't take me seriously, just poking some fun Quote
Guest Posted February 10, 2007 Posted February 10, 2007 I don't know about Pa. Tony, but up here most E-Break cables freeze from lack of use. The one on my car is frozen and waiting to be repaired. Ken Quote
Guest Posted February 10, 2007 Posted February 10, 2007 you must be married don't take me seriously, just poking some fun Oh Yeah !! My wife is cool she encourages my toy habbits !! Stopped at the liquor store on the way back from the parts store Quote
Victor Posted February 11, 2007 Posted February 11, 2007 Now I don't know if the thread has changed or not Are we still stuck in park? I went out and looked at one of our cars and it says, "Apply brake before shifting from Park". Quote
Riznitch Posted February 11, 2007 Author Posted February 11, 2007 is there a relay attached somewhere to the brake that may cause the shifter not to go in gear? if so where? i have a 72 just for a reminder. Quote
Guest Posted February 11, 2007 Posted February 11, 2007 The brake has nothing to do with shifter as far as I know. That technology did not show up until the 90's. Did you check the cable ? if you unhook it from trans and shifter you should be able to move it back and forth by hand. Quote
Riznitch Posted February 11, 2007 Author Posted February 11, 2007 yep, its not hooked to the tran and still the shifter won't move.i havent un hooked it from thr shifter though. Quote
Riznitch Posted February 13, 2007 Author Posted February 13, 2007 okay, i give up. where can i find a gm console shift cable? Quote
Guest Posted February 13, 2007 Posted February 13, 2007 E bay where else http://cgi.ebay.com/ebaymotors/1969-1972...sspagenameZWD1V If you keep an eye out you might find one cheaper on e bay. The cables are the same for chevelle floor shift cars. Like I said in an earlier post I bought an aftermarket cable but it was crap so I bought a gm cable and all is good. Like the saying goes ( you get what you pay for ) Quote
