Soler89 Posted September 10, 2017 Posted September 10, 2017 As a few if you know, I recently got my hands on a 72 MC with a 350 a week ago. Last night I finally heard it run, even if it was for a few seconds. I tried replacing my fuel pump, but the nut connecting to the fuel line to the carb is stripped. The rubber line is also dry rotted. I want to replace the fuel pump and the line. My question is, can I just replace it with a steel braided line, or should i just look for a direct replacement (fuel pump to carb line). Quote
Paul Bell Posted September 10, 2017 Posted September 10, 2017 Rubber lines are fine if they're in good condition. There are a handful of rubber hoses at the gas tank, you should climb under there and have a good look at them. Did you use a flair wrench on that stripped nut? Quote
Soler89 Posted September 10, 2017 Author Posted September 10, 2017 I have not. My buddy told me to get one and try that before i purchase anything new (except the rubber, they were bad). Ill head to the store and grab one today. Quote
stangeba Posted September 10, 2017 Posted September 10, 2017 I replaced all the hoses on my 71. There was a "hidden" restricter in one of the hoses at the tank. Here are some pics: 1 Quote
GatorDog72 Posted September 10, 2017 Posted September 10, 2017 Don't bother with stainless braided line, unless you plan on racing. Rubber ones work just fine and are MUCH cheaper than stainless. For the pump to carb, I'm sure someone makes a replacement pre-bent metal line. Quote
Soler89 Posted September 10, 2017 Author Posted September 10, 2017 yep. Now i need a pre bent line. I couldn't get the fuel pump off, so i took them both out together. The flare wrench didn't work either. Quote
Paul Bell Posted September 10, 2017 Posted September 10, 2017 I replaced all the hoses on my 71. There was a "hidden" restricter in one of the hoses at the tank. Which hose was it in? Quote
stangeba Posted September 10, 2017 Posted September 10, 2017 Paul, I believe it was in the vent hose as shown in the drawing, there is a mark on the hose in the drawing but NOT on the real hose where I found it. I almost threw it out but saw a bulge and cut the hose open o find the small plastic plug with a small hole in the center of it. I wonder how many of them got thrown out!!!!!!!!! I still have the full entire evaporative emission system, many have been removed. Bruce Quote
Paul Bell Posted September 10, 2017 Posted September 10, 2017 Very interesting. I suppose that would allow vapors to seep through slowly. Quote
stangeba Posted September 10, 2017 Posted September 10, 2017 Paul, I don't know but my 71 (today after a 30 mile drive) smells up my garage like crazy. I believe it is all coming from the stock Qudrajet carb. Bruce Quote
Soler89 Posted September 14, 2017 Author Posted September 14, 2017 Well I finally installed the new pump, installed the line that came today, and had it all ready to go. The pump works, which is good. The car started and stay on for about ten seconds, 5 seconds longer than last time when the fuel pump wasn't working. After the ten seconds, it cut off. We poured fuel down the carb, just a little bit, started the car up and fuel started shooting out of the top of the Holley. It's been a long tiring day, I don't even know where to begin with the fuel shooting out. Quote
Soler89 Posted September 14, 2017 Author Posted September 14, 2017 Also, last week was literally my first time touching a carb. I don't know much about old cars, but I'm a quick learner. Car was sitting for 3 years before I got my hands on it last week, if that helps. Quote
GatorDog72 Posted September 14, 2017 Posted September 14, 2017 Most likely some garbage stuck in the float assembly or a sunk float. Try tapping lightly on the float bowl to see if it stops flooding. Don't use a giant hammer, a screwdriver handle is plenty. Quote
cny first gen 71 Posted September 14, 2017 Posted September 14, 2017 Aren't them holly carbs a pain to adjust the floats on? I really don't know that much about them. Quote
GatorDog72 Posted September 14, 2017 Posted September 14, 2017 Aren't them holly carbs a pain to adjust the floats on? I really don't know that much about them. They aren't bad at all, especially the ones that have the glass windows on the float bowls instead of the screw. I prefer 4150 or 4500 Holley's over any other carb for their tuning options. Quote
Soler89 Posted September 16, 2017 Author Posted September 16, 2017 UPDATE. No more fuel shooting out. I just can't get the car to stay on for more than one or two seconds. Ive been adjusting the carb all morning the other day, so im getting really familiar with working in the carb. I posted videos on facebook and someone pointed out that my electric choke was not wired up. I didnt know what that meant, so I researched. The positive wire wasn't even on the choke. So I ran the wire to to IGN and connected it to the choke. Still no difference. Im gettin stumped. It sounds like the car really wants to run. Wired Quote
Soler89 Posted September 17, 2017 Author Posted September 17, 2017 I took the fuel bowl off. My buddy says it looks clean. I asked him about the float itself, he said it should move freely. However, my float gives me a lot of resistance when I try to move it with my fingers. Is this normal? Quote
GatorDog72 Posted September 17, 2017 Posted September 17, 2017 It almost looks like the tab on the float is bent. First thing I would do is soak that carb in some carb cleaner, it looks pretty gooey. The float should have a little bit of resistance to it, but not a lot. If the fuel level can't move the float then its going to flood out. Get some new bowl gaskets when you put it back together. Those look like they are starting to come apart. 1 Quote
Soler89 Posted September 20, 2017 Author Posted September 20, 2017 UPDATE: Cleaned the bowl section on the carb. Float moves much better now. New gasket installed also. After tinkering around, this is where I'm at... The Monte can start after pumping gas in the carb 3 times. It can then stay running for a minute to five minutes. Eventually it just stops. After it stops, it's harder to start, but can be done after pumping some gas. This time I have to keep my foot on the gas to keep it running. If I take my foot off, it dies. Here's a link to the video of it running. https://www.instagram.com/p/BZNDpT7nLOr/ Quote
GatorDog72 Posted September 20, 2017 Posted September 20, 2017 Try a float adjustment next. What's the number on the carb you are working with? Quote
Soler89 Posted September 20, 2017 Author Posted September 20, 2017 I sent a pic to Holley and they said it's an 80457. Quote
GatorDog72 Posted September 21, 2017 Posted September 21, 2017 In case you don't have them already, here's a link to the instruction manual for your carb. http://documents.holley.com/199r11081.pdf Quote
Soler89 Posted September 28, 2017 Author Posted September 28, 2017 So I get the car back from the shop. Gator, as you know my fuel sending unit needs to be replaced. Bit they also said my carb might need to be replaced. Looks close to new to me. Should I just tear it down and clean it all? Quote
Soler89 Posted September 29, 2017 Author Posted September 29, 2017 Sorry for being vague, I had to rush that post. So, I had my fuel system cleaned and has some inspections done in the car. The fuel sending unit works, but it has surface rust on it and the sock is torn up. They recommended replacing my unit. They then informed me that all the bad gas could have possibly damaged the carburetor. They reccomened changing it out. I'm not an expert, but could old gas actually damage the csrberator to the point that it gets physically damages beyond repair? Would me taking it off, completely soaking the soakable parts in carb cleaner bring it back to new? I already have new gaskets for it. Quote
