Tdub Posted November 8, 2017 Posted November 8, 2017 I'm in the process of a complete restoration on my automatic 70 that I've owned since the summer of 1990 (I was 19 when I bought it for $2500.) I'm doing the conversion to buckets and have parts from a donor MC including the original console (bare) steering column. It was pretty spanked and I decided that I would simply use the smooth sleeves from the donor column and swap them onto my original column shift column. I tore into the donor column and it took me a while to extract the smooth sleeves to paint and swap. I'm now a little hesitant to perform the surgery on my perfectly functional but soon-to-be incorrect column to swap in the smooth sleeve. Is this even possible? Am I stupid for not seeking out a factory column set up for the floor shifter? I'm fairly mechanically proficient but I've never been into a steering column before and I'm unaware of what's going on in that column shift mechanism. Quote
Mike Brichta Posted November 8, 2017 Posted November 8, 2017 Where in PA are you located? I am in Center Valley PA (18034). I just converted my bucket seat auto console car to a 4 speed console car and have lots of parts that might make your conversion a lot easier that I just removed from my car in the last 2 weeks. I have things like bucket seats, floor shift steering column, console top plate, console shifter with neutral safety switch, shifter cable, shifter brackets, etc., etc. I know how much time it took me to track down all of these parts when I did my conversion. The only problem is that I am currently on the way to AZ for my son's wedding. I will be returning the end of next week. If you can wait that long and want to check out what I have let me know. Thanks!! Mike Quote
72 Monte Carlo Posted November 8, 2017 Posted November 8, 2017 Mike, You posted in my interior thread and I have sent you the last PM regarding a shipping cost for the bucket seats, but I haven't heard back from you yet. Please let me know. Thanks, Doug Quote
Tdub Posted November 8, 2017 Author Posted November 8, 2017 Mike, I'm in northwest PA (kinda near Erie) 5+ hours from you. Well if I tear into my working column and can't substitute the smooth collar, at least I know where I can find a console column. I think I have all of the other pieces I need to convert. I took all of the stuff from a donor car that was being scrapped probably over 20 years ago. In hindsight, I should have taken the entire car. In any event I'd love to hear from someone who has tried this or otherwise been into the innards of a column. Quote
footballubet Posted November 9, 2017 Posted November 9, 2017 Todd, The steering columns are pretty simple. I've had well over 100 of these apart through the years. Take your time and lay each piece in order that you remove it. I have some very good files with pictures and procedures that I will find and send to you. I'm South of you several hours in Leechburg. Maybe a road trip would be in order if you run into problems. Quote
Tdub Posted November 9, 2017 Author Posted November 9, 2017 Scott, do I understand you to say that it is possible to convert the old "column shift column" to a "console column" by swapping in the sleeves, i.e. the rotating portion of the column from my donor "console column"? I already have removed the sleeve from the donor column but I haven't torn apart the original "column shift column" to know what's going on inside of it. If it isn't possible to swap, I don't want to mess with and possibly trash a serviceable column. I'm certainly mechanically proficient enough that I can perform the surgery but when I comb through the prior posts, I can't find any that indicate the swap is possible. Quote
cbolt Posted November 9, 2017 Posted November 9, 2017 I own a Saginaw steering column repair manual, and I am fairly certain the contents should be available on the internet somewhere with a search. I have been into many a steering column over the years as well, they aren't that complex. When I swapped my column to a console shift I used a donor column so I cannot answer your question about the sleeve swap. Once you break everything down I am pretty sure the parts interchange but cannot say for certain. Good luck! The conversion is a pretty easy project if you take your time. Quote
Tdub Posted February 7, 2018 Author Posted February 7, 2018 In case anyone wants to make this modification, please allow this post to serve as an update to the original query. It turns out that the sleeve swap is possible and relatively easy to do. The smooth sleeve simply takes the place of the original shifter sleeve and shifter. As I'm sure most of you know, the gear indicator in the dash is not correct on a floor shift model. I believe a floor shift model has the gear indicator blacked out in the dash. However, the smooth sleeve has the hole to attach the cable operating the in-dash gear indicator so it can still be used. If you didn't know what you were looking at, you wouldn't know it didn't belong. Pretty happy with the outcome. Quote
RealRed70 Posted February 7, 2018 Posted February 7, 2018 For a floor shifted car the speedometer assembly is different and does not even have the opening for the shift indicator. The speedometer would have a solid face. There are no shift indicator parts on that style of speedometer assembly. Quote
stangeba Posted February 7, 2018 Posted February 7, 2018 Todd, Happy it worked out for you. Did you take any pictures of this modification process? My column shift / tilt wheel was loose and wobbled so I tore it apart to tighten the bolts. What a job, much harder than I thought but it turned out great, no more wobble. Bruce Quote
Tdub Posted February 9, 2018 Author Posted February 9, 2018 Unfortunately I didn't photograph my efforts. The biggest challenge I had was paint matching. I have a Gobi Beige exterior and a Sandalwood interior. The column had a funky unknown color darker than the rattlecan Sandalwood I was able to locate. I want to a local body man and we eyeball paint matched to a 2017 GM interior color. Unfortunately, it was new enough that I couldn't seem to locate that color in a rattlecan. It was only available in larger quantities and at an outrageous price. Ultimately I had a local autoparts guy hand mix the color by eyeball and squirt it into a rattlecan for me for around $35. It came out pretty close to the original. I went to my body guy (my neighbor) last night and he's finished the paint. He'll bolt on the hood, fenders and front bumper next week and body will be done. I'm waiting for a local Amish upholstery guy to finish custom making Sandalwood cloth bucket seat covers and covering my new seats. Then it's on to me putting the new interior in the car. I'm torn as to whether I'm going to tackle the headliner myself or hire it out. After owning this car for 28 years, it's finally going to look really presentable. My dad bought the car for me when I was 19 and just died in December of 2017. I'd really hoped to have it done before he died so he could see it. I at least was able to take him to the shop to see the progress before he died. I guess my next project will be tinkering on his '62 Pontiac Catalina. Quote
stangeba Posted February 9, 2018 Posted February 9, 2018 I never did anything with any headliner, I assume it would be very difficult. My dad had a 62 4 door Pontiac Catalina after my older brother crashed the family 56 Ford 4 door. Good times! Bruce Quote
farmall Posted March 11, 2018 Posted March 11, 2018 I did my own headliner. It was a little challenging but possible. I will probably do it myself again. Quote
farmall Posted March 11, 2018 Posted March 11, 2018 By the way, I would like to buy one of the smooth collars for the steering wheel if anyone has one they would part with. Quote
RealRed70 Posted March 11, 2018 Posted March 11, 2018 It is very easy to modify you existing collar to the smooth type. Quote
